Healey 100M Cold Air Box Hose Fitting
Papa Law
I have purchased an original reproduction Healey 100M 4" rubberized canvas over wire air box hose from A H SPARES in the U.K.. It will collapse and clamp on the end of the cold air box as it came from the factory. However, I am not sure how to approach the fitting. Do you have to cut the bottom of the hose so it can overlap and secure a tight fitting? I don't want to start cutting if there is another method as the hose was expensive.
Thanks for any help!
Michael Oritt
If you have the correct hose and CAB the hose should go over the end of the box and secure with a hose clamp. This assumes that your car is equipped with the special angled support for the shroud that creates room for the hose, even with the correct bracket--or no bracket at all as some folks have done--in any case it is not an easy job to do. DW sells, or used to sell, a rectangle to round sheet metal adaptor that plugs into the end of the CAB and offers a circular end that more easily and neatly fits to the hose, but even with it I still had problems making the hose transition from the grill to the CAB and had a custom-made aluminum adaptor made.
After many years of struggling I recently removed the CAB as I was tired of slicing up my hands and arm when attempting to adjust the carbs, etc. It's an iconic piece of gear but it is questionable whether it really delivers any performance benefits and it certainly has its drawbacks.
All that said, good luck!
P
Papa Law
Thanks for the info, I have experienced every thing you said, but was hoping for a silver bullitt I am currently running a David Welsch sausage filter which is easy to work on carbs, runs well but obviously does not look as good as the CAB.
Working in the CAB area has a way of eating your hands up!
MikeAH100M
I've had the same problem trying to fit the hose. I also don't like the idea of not having a filter. I tried adding a K&N filter and mounting to the wheel well but had trouble keeping it in place. I read on this forum (can't find the reference) or somewhere else that testing showed velocity stacks added more to performance than the CAB. I've also seen examples of people drilling a hole in the end of the CAB because they felt that back carb was getting starved. All that said, I think going to velocity stacks with filters is my next step.
That may have been me. I read an article years ago about a 100 racer who tested on a dyno and found velocity stacks yielded more HP than the CAB. I used the DWR adapter and some of the rigid tubing as used in the fresh air port, fashioned an adapter bolted it to the top of the steering box with a K&N filter (the adapter had to be modified to fit the tubing).
MikeAH100M
Never thought of strapping it to the steering box. Great idea! Thanks
DTDuck
You can do both the CAB and Low Profile Velocity stacks like this (https://www.minimania.com/part/SS53/Austin-Mini-Stub-Stack-For-The-Hif44-Billet-Aluminum) They make them for 1.5, 1.75 & 2" SU's I used to use this type on my Spridget Racer years ago and they do work well.
Cheers,
Dan M.
IIRC, the CAB is fitted with studs that go through the carb bodies. I don't see how you'd fit these in a CAB. I do have these on my BJ8 with K&N filters.
Michael Oritt
I recently put in velocity stacks in place of the CAB. I really have not noticed any increase in performance but they look and sound great and my forearms appreciate the swap. At the time of this photo a small breather/reservoir venting from the valve cover was still installed, clamped to the front velocity stack, but I removed it when I last adjusted the carbs and have gone to a straight hose since there is no perceptible blow-by.
DTDuck
Probably have to replace the studs with bolts & nuts. Might be a bit fiddly, but I bet it could be modified to work.
Dan M.
CraigC
The original cold air box was attached with bolts. Unlike one replica version of the CAB that apparently uses some form of nutsert fixed to the aluminum box, the originals had a metal plate with welded nuts that was riveted to the inside of the CAB. I have seen that Sports and Classics (NFI) sells a replica that uses this OEM style mounting. The OE style would definitely not allow fitting of any sort of velocity stack. The "other" replica could probably be modified to allow use of the Low Profile Velocity stacks without too much trouble.
It would be very easy to fit studs to an OE CAB, although that might actually make it harder to get all 4 lined up at one time. I have considered doing this on several occasions.
Currently my CAB is on the shelf awaiting some crack repairs. In its place I have fitted the low profile velocity stacks inside a pair of Lynx-type foam filters. Hope to find out shortly how it runs and sounds with this setup.
Ignoring the fact that my engine has a couple of extra cylinders (and 3X the openings) that's pretty much how this unified air filter housing & low profile velocity stub-stacks are attached. The Webers already have studs in them (5 or 6 mm dia./nuts are 10 mm across flats, and requires a highly modified open-end wrench to access them). Standard Weber rectangular x 1-3/4" high filter elements straddle the stubs-stacks, and a stainless steel panel slips in to secure them.
I made the box a 2-piece design in the likeness of a 100M CAB, but it would've starved the engine of air without the added holes in the ss panel and the box itself.
Test-fitting the cover, before holes were punched. Hard to describe, but with slots in the top of the box, it slips inside the opening at the ends and bottom for a very secure fit, only requiring screws along the top (had to be able to remove/replace cover for filter maint.).
Holes were cut with a Greenlee 1/2" conduit K/O punch (7/8" dia.) and then belled with a punch & die a machinist friend made for me.
Stevec9000
View attachment 49124I have ordered a K&N RU2590 filter and will try to match your setup. Someone posted to use a trimmed tuna can to give it support. Here is the post I found: This read-only message was archived from a public mail list.
Mail From: Dave & Marlene <(email redacted)>
Hi Juanito,
Cold air boxes can be quite effective to increase engine power. ie. air
density increases about 2% for each 10 degreeF drop in air temperature.
An example would be a drop from 200 degrees engine bay temperature to
100 degrees outside temperature would give 20% increase in intake air
density & 20% increase in engine power. You might need to use the richer
OA6 carb needles in place of the standard OA7 needles. Where else can
you get so much gain for so little work? A secondary benefit is that the
carbs run much cooler also.
As far as filters, I have had good results with a K&N cone type filter
mounted on the forward end of the air duct. To make servicing the filter
easier, I used wing nuts on the upper grille mounting studs. You can
reach in through the front wheel openings & remove the wing nuts without
raising the car. Once the upper nuts are removed, the grille just swings
out at the top & unplugs from it's lower mounting pegs. A straight &
open access to the filter which doesn't need to be serviced very often
anyway.
I used a K&N # RU2590 filter. It is a truncated cone with a 4" ID rubber
connecting flange, 5 3/8" diameter at the base, 4 3/8" diameter at the
end, & is 7" long.
To ease removal & installation of the box to carbs, I secured studs in
the air box threads with Loctite & use nuts on the carb side of the
studs. Much easier to push four studs into their respective carb flanges
than to fight each bolt one at a time into the holes. Once the air box
is on, it doesn't need to be removed very often.
As you probably know, the front top shroud bracket needs to be replaced
with an offset bracket & the vertical shroud support bracket bent
outboard to match the offset bracket.
I can give further info & pics if you wish.
Dave Russell
BN2
I recently added a small set screw at the front of the CAB to keep the adapter from sliding out. I try to keep this car as original as possible, but I'm not fanatic about it (note the rigid tubing and adapter aren't OEM; at the factory they just slapped some flimsy SCAT-type tubing on it with a band clamp and called it a day) . I live in the (sometimes very dusty Central Valley) so going filter-less isn't an option IMO. Now, I have to take it all apart to figure out how to get corn head grease into the steering box (a buddy sent me a couple tubes kinda as a joke when my box peed all over the garage floor, but I'm going to give it a go; a very respected Canadian restorer said he puts in all the cars he fixes).
CABs and modified intakes are a subject of much debate; I've seen dyno runs (on TV) where they'll add maybe 5HP to a 500HP engine; and my sorta uprated Mustang came with the GT350 CAB, throttle body and intake and probably a 'tune' and supposedly is capable of 20 more HP than a stock GT (480 vs 460). The one on the M cars is a real PITA to work with/around, but they do look cool. Aftermarket CAB kits for modern cars got popular maybe 20 years ago, so DMH and Geoff were ahead of the curve.
I've seriously considered that myself, and may yet swap in a couple K&Ns.
One thing Dave R. didn't consider, apparently, is that forcing the cold air to make a sharp 90deg turn to the carburettors probably obviates the advantage of the air charge being cooler (hence the advantage of velocity stacks; IIRC, Dougie has those on his racer).
red57
I've been a big fan and user of stub stacks for several years because they fit inside air cleaners and can work just as well as velocity stacks. Picture of a page in How To Build Horsepower by David Vizard (c 1996) shows changes in airflow for various different shapes/sizes of ram pipes and a stub stack - of all of these the stub stack gave the biggest improvement.
Dave
Stevec9000
I ordered the Dennis Welsh CAB adapter/filter kit. Unfortunately I could not install it as the adapter adapts the rectangular box to a larger 4.5 inch round hose not the factory 4” hose. The large, rigid hose they supply will not fit past the original factory 100M shroud bracket.
Editor_Reid For Sale 1956 Austin-Healey 100M [real one] Austin Healey Classifieds 0
lbcspinners Austin-Healey 100M auction on BaT! Austin Healey 36
Bob_Spidell Here we go again!: What is [and isn't] an Austin-Healey 100M? Austin Healey 3
HealeyRick 100M - The Most Overvalued Healey? Austin Healey 18
Editor_Reid >>> What is [and isn't] an Austin-Healey 100M? Austin Healey 0
H 1956 Austin Healey 100m factory on Ebay Austin Healey 20
G Healey 100-Lemans-100M Austin Healey 6
W Austin Healey 100M Spridgets 2
A Austin Healey BN4 - Paint color codes Austin Healey 0
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13th-15th Austin Healey 0
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
C What to do with my late father's Healey 100 Austin Healey 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
B Healey Won't Start - No Spark Austin Healey 38
Editor_Reid "Austin-Healey Quarterly" e-zine Spridgets 2
Editor_Reid "Austin-Healey Quarterly" e-zine Austin Healey 8
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
HealeyRick Perfect Healey Floor Jack Austin Healey 14
T Netflix Christmas Film with a Healey Austin Healey 4
