TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum
mgf
Group: I have a question.
1959 Triumph TR3A TS43919L (Nice Survivor)
FRONT SUSPENSION (ref Bentley Manual FRAME UNIT: Drawing # 265 SIDE VIEW of UNIT
QUESTION:
Is the fulcrum SHAFT for the Lower Control Arms
1. a Continuous THROUGH-Shaft or
2. two (2) STUB-Shafts?
I may want to replace the Passenger's Side forward portion due to rust.
I think the car may have been stored in a company warehouse for much of it's life (64k miles),
but in this particular area, I found surface rust (due to leak in roof?) but no rust at all on the Driver's Side?
I can remove the rust by selective sanding but I'd rather replace this portion of the fulcrum shaft as,
this is the surface upon which the new forward nylon bushing will rotate.
Thanks,
mgf
bobhustead
It is a single shaft. Proper alignment is quite a chore on replacement. Given the support to the frame on both sides of each control arm, even rusty it is very strong. The failure point tends to be where the support brackets are welded to the frame. You might want to clean these joints thoroughly to look for cracks and the need to overlay new welds.
M
mgf
I was hoping it was two stub shafts but so much for hoping.
I will proceed with selective sanding & see what I end up with.
Fortunately, it will be a nylon bushing rotating on a metal shaft.
The nylon bushing can be replaced, if required, at some future date.
I will clean & inspect the support bracket welds as you mentioned.
Thanks for your feedback.
mgf
2long
Can anyone describe what is involved in either replacing the shaft, or replacing both the bracket and shaft? How is proper alignment obtained?
Dan
M
mgf
Dan
Dan,
I spent my work lifetime in Engineering/Design creating Design Drawings & approving Detail Shop drawings but mostly Structural vs Mechanical.
If I were going to do it, I would make a drawing using dimensions taken from measurements of an actual unit. I'd use the Bentley Manual drawing ref
I gave in the original post as a starting place. I'd then hire someone with machine shop, fitting/welding skills to machine/fabricate the the shaft & bracket
then weld it in place using a jig (which may be what the factory used?).
There are some knowledgeable, experienced & skilled people on this website, hopefully, someone who has done it will respond.
mgf
bobhustead
Dan
As a kid, I had one torn off the frame altogether from roughhousing on dirt roads. I tried to fix it using measurement from reference points. Didn't get it quite right and I don't think you could. Is yours completely off?
martx-5
Do you realize that there is a replaceable steel sleeve/bush that goes over the shaft that goes all the way through?? That is the steel piece that the nylon bushing rides on. That's the rusty piece that I think your inquiring about. That can be replaced. It just slides over the through shaft. Well, you may have to mess around getting the old ones off. See item #118 in the Moss parts link below...
https://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29136
2long
Replacing the steel sleeve that goes over the shaft can certainly help if the shaft is just a little pitted or worn. But when I redid the suspension on the TR2, the shaft was so pitted and worn that the steel sleeve fit pretty loosely, and the bracketry had some bent flanges. I think the corrosion plus a few curb knocks, or aggressive driving over big ruts, can wrench the shaft around or bend the bracket. The bracket itself is available (I think Roadster Factory) and it has to be welded to the frame. That is the job I was wondering about, or possibly how to assess if just the shaft can be changed. Both sound like major propositions.
Dan
bobhustead
The replacement sleeve is a bit longer than the part of the fulcrum on which it rides. It is held still by the pinch of the nut, not its diametric fit to the fulcrum.
M
mgf
So collectively, I got all the info that I needed.
This AM (my 80th Bday) I put some heat to the forward STEEL Bushing & it came right off the through shaft.
The photos are for sp53 (I wasn't ignoring your request) & those who may have a similar experience in the future.
Thanks to all who responded
mgf DSCN4207.jpgDSCN4209.jpgDSCN4208.jpgDSCN4210.jpgDSCN4211.jpgDSCN4212.jpg
TRopic6
FWIW, Moss shows a part number for the fulcrum shaft: 031-703. i ran into th same problem on my TR-3A restoration 20+ years ago and just replaced the metal bush. Replacing (and aligning) the shaft would be lots of work, but that part would be an option in case of severe rust or damage.
Jeff
sp53
I did the same thing to my frame heated them up and much to my surprise they came off. I think they come in some of those suspension rebuild package deal kits, perhaps TRF or maybe Moss. Then I remembered you said you are out there at 80 working on a tr3. Happy birthday=== and I for one am dam glad to hear that.
steve
M
mgf
steve
Steve,
Thanks for the Birthday wish!
I purchased TRF's "Magic Kit" last year (2016) when it was on sale. It includes the subject steel bushing.
Now, Bob has me wondering why he cautioned me that they will not fit?
Still learning at 80!
mgf
bobhustead
The plastic element of the new bushes was too big (diameter) so that when you put the plastic on the sleeve and pushed the assembly into the control arm the system was locked up. I had to put the plastic part in a vise and scrape the outside with a razor blade and, after a long while, was able to whittle them down to a desirable snug fit. And a bit of lagniappe from TR3 Driver (Randall)- don't use anti-seize grease on any surface that contacts the plastic bush. It has metallic powder in it that will rapidly abrade the nylon.
sp53
Well I never heard that before, I would need some pictures again. I took them off my car with heat and twisting then put the ones from the kit on and everything seems fine, but I am still building this car, but again I have rebuilt many of these over the years and never heard about the nylon bushing being ruined. The old tr2s and early tr3 had rubber down there maybe that is what he is talking about because I think Randall drives a 1956.
steve
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
bugedd Front suspension and oil pan Spridgets 17
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
F TR2/3/3A front suspension Triumph 3
