Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 101
Thread: Knock knock... what's this?
Discussions of Triumph motor cars
  1. #81
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,499
    Thanks Thanks Given
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Re: Knock knock... what's this?
    And the small cam lobe is for the fuel pump. Which, by the way CAN cause a knock too for certain failure modes.
    John
    1955 TR2
  2. #82
    Jedi Hopeful HighAltitudeTR3's Avatar
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    Yes, obviously not valve guides... have too many projects on this car going at once. 😜 Luckily I attached a photo so it was very obvious those were not valve guides. I thought the cylinder walls were scored, but I don't fee anything there. Keep searching. Will test clearance on the old main bearings with plastigauge tomorrow and hopefully pop the new ones in and viola! We'll see.
    *1959 TR3A
    *1951 Chevy Fleetline Deluxe
    *1986 GMC Sierra Classic
  3. #83
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    Just a quick update: I ordered the wrong seals so I have a couple more days until I get the right ones in. But I did check the clearence with Plastigage. I am showing .002 on the con bearings. That doesn't seem like that big of a gap. Worth the knock?
    *1959 TR3A
  4. #84
    Jedi Trainee Merlin63Tr4's Avatar
    Join Date
    Nov 2006
    Location
    Milpitas, CA. U.S.A.
    Posts
    236
    Thanks Thanks Given
    Thanked in
    You have to be careful how you measure clearances with Plastigage. All oil has to be wiped from surfaces to be measured, care must be taken to not rotate the surfaces being measured while the Plastigage is in place, etc, etc.
    Is the above measurement with the new bearing shells or the old?
    Big end bearing clearances when the TR engines were newly manufactured were in the range of 0.0028 to 0.0040......
    M.
    Merlin the '63 Tr4.... it grows younger !
    "A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools." -- Douglas Noel Adams (1952-2001)
  5. #85
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    Thanks for the reply...
    It was wiped and steady
    this was the old bearing. I will measure the difference with a micrometer on the new shells vs. the old shells when I receive them. Fingers crossed I can wrap this up with some success, I don't know what else I can check!!
    Anything else before I close the bottom?
    *1959 TR3A
  6. #86
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,499
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Are you using a mechanical fuel pump?
    John
    1955 TR2
  7. #87
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    I am using mechanical fuel pump...
    *1959 TR3A
  8. #88
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,499
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    That very well could cause a knock...but the more i think about it, it would not stop by pulling the ignition lead. So, never mind!?!
    This is an odd one. Another possibility is carbon in the head combustion chamber. If everything else in the bottom end is tight, then pulling the head would be the next step.
    John
    1955 TR2
  9. #89
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    My only guess is the little bit of wear that was ok the rod bearings. And I will post my findings when I get the new ones installed. I would like to confirm the passage for oil is clear in the crank, but I don't like the idea of blasting air in there. I am worried it could cause a much worse block as well as leaving a void air in the crank, maybe a block elsewhere? Is there any way to check if there is a block by somehow pushing oil through?
    *1959 TR3A
  10. #90
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,499
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    By now all the oil is drained from the crank anyway, so adding air is not going to hurt anything. You should see it bubbling out the rear main. You cannot impose a block unless there is already something in there to block it. The oil hole is just a drilling from the rod journal to the rear main journal. .003" bearing clearance is not enough to cause a knock, unless there is no oil reaching the bearing.
    An oil blockage is a long shot. I no longer think it's the bearing. It has to be piston related.
    John
    1955 TR2
  11. #91
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    Yeah, you got a point...
    do you blow air from the hole in the crank journal?
    What more can I check with the piston with the bottom off? I am going to compression test engine when I get it buttoned back up. Oil pressure was good...
    *1959 TR3A
  12. #92
    Join Date
    Feb 2016
    Location
    Macon Georgia
    Posts
    1,069
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Have you checked the small end for clearance? Grab the end of the connecting rod and try to move the piston up and down. The PO may have left the small end bush off the No. 4 rod.
    David
  13. #93
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    I have. I actually took a video of it, but it's such a frustrating video because I'm just fumbling around in a really tight spot. The only bit of "play" is at the wrist pin from side to side... nothing lateral.
    *1959 TR3A
  14. #94
    Join Date
    Oct 2012
    Location
    Albany, OR
    Posts
    369
    Thanks Thanks Given
    Thanked in
    To me, the noise sounds like the double knock from a loose small end bushing. It is especially noticeable when removing and replacing the spark plug wire.
    Berry
  15. #95
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    Well, here is the original video: https://youtu.be/xgi8RZ6x6qY
    here is a video from today new bearings in: https://youtu.be/1lS9ftg_1wc
    What do we think?! Out of the woods? What else is going on with this engine?
    *1959 TR3A
  16. #96
    Yoda CJD's Avatar
    Join Date
    Feb 2011
    Location
    Southlake, TX, USA
    Posts
    4,499
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    There's no denying it's much better! I still hear a slight knock, but I'd personally wait until it gets more pronounced before digging into it.
    Is the consensus that the old bearing shells were out of tolerance?
    John
    1955 TR2
  17. #97
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    That's kind of what I'm thinking. I think I'll drive it like this for awhile, if the knock comes back, I will probably end up having to get a rebuild. I think the knock is a two fold knock I am going to replace the manifold gasket next and see how that helps.
    need to set the timing and get the carbs dialed in. I feel like I'm idling very high~950 rpms
    *1959 TR3A
  18. #98
    Join Date
    Nov 2006
    Location
    Posts
    236
    Thanks Thanks Given
    Thanked in
    It sounds like a typical TR engine with a few miles in it.
    You can still hear the knock, but it is not very noticeable.
    Still wonder why the excess wear on the No.4 bearing shell and not the other three.
    M.
  19. #99
    Join Date
    May 2017
    Location
    Aspen, CO
    Posts
    164
    Thanks Thanks Given
    Thanked in
    Quote Originally Posted by Merlin63Tr4 View Post
    M.
    i bet there was a clog in the oil at some point. With the score marks running from the oil holes on the bearing, it seems like some grit probably worked its way through there.
    *1959 TR3A
  20. #100
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    2,548
    Thanks Thanks Given
    Thanked in
    Yeh much better without the spark waking away, I still do not like the hollowness I hear, and yes the problem does not have to be one thing. Maybe bottom end and valve train together. I hear a typical TR3 valve train and==== yes a little== to a lot=== too loose. Have you slid one of the rockers over and felt the bottom of the rocker shaft. you have too loosen up the adjuster with the piston up..
    TR3s chew those shafts up for some reason, but perhaps it is the originals that I have taken out over the years, but what I am saying is the shafts can get very worn deeply and the motor runs fine=== but makes noises and it cannot be fixed without replacing the shaft and usually re-bushing (which I do not recommend) or replacing the rockers. I would seriously think about doing that because it has to be done anyway, does not cost that much and the motor and stuff stays in the car and the access is easy. Wish I was there I would feel more confident about my diagnoses.
    Bottom line is you are a TR3 guy now, so now=== you have to fix it, and yes===== I did see a Rabbit run through here.
    Steve
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
