About to re-install my fuel tank Series I E-Type
Administrator
Boss
I am about to undertake what promises to be one of the more difficult tasks on putting my E-Type back together: re-installing the fun tank! I've watched a coupe videos of the procedure and theres been one common theme - it ain't easy!
Wish me luck!
Gliderman8
It's a tankless job but you'll get it done.
Geo Hahn
Like one of those metal-wire puzzles I got for Christmas - seems like it won't go until you suddenly find that sweet spot and everything falls into place.
If you have seen the videos then you probably have a pretty fair idea of the sequence.
One thing I did was cut a notch in the fill hose rather than shorten it to get a good connection to both filler and tank:
Geo Hahn
Now looking at my notes -- I see that the grommets didn't want to stay put as I maneuvered the tank into position. To remedy that I tied them in place using dental floss.
Floss is quite strong yet thin enough to not interfere with the bolts. When all is buttoned up it is slippery enough to slide out after being cut loose.
Administrator
Boss
Brilliant! I've been worried about getting that filler howe up far enough out of the way! I take it that notch allowed you to push the filler hose up farther than normal because the vert pipe comes out of the filler neck?
Administrator
Boss
Did you use new grommets and spacers? I bought new grommets with new spacers from XKS. The new grommets fit VERY tight on the spacer tubes and in fact I had to figure a way to get them onto the new spacers as I could NOT get the grommets onto the spacer tubes by hand. Once they were on and installed on the tank they were tight! They are not going to be a problem coming loose. Here's a video I made of the process:
A Fuel tank sender - direction to install? Austin Healey 3
M TR2/3/3A TR3 fuel cap install question Triumph 9
Gliderman8 Electric fuel pump install help... please Triumph 24
drooartz New specific plan for fuel pump install Spridgets 23
tosoutherncars Weber DGV, cont'd... Electric fuel pump install Spridgets 19
Monark192 SU Fuel Pump Install Question MG 4
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
R TR2/3/3A Install new wiring harness in steering column Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
C How to install Stone Guards on driving lights? Austin Healey 7
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
B TR2/3/3A Cigarette Lighter Install Triumph 7
D Prepping to install engine Spridgets 2
P BN2 new wood steering wheel install Austin Healey 5
C MGB Paint first or install mechanics MG 10
T TR4/4A Rear Seatback/Hoodstick [Top] cover install Triumph 0
D BT7 Timing chain install Austin Healey 2
CessnaTPA Tonneau Install Question Austin Healey 13
