TR2/3/3A Vacuum advance questions
6TTR3A
My distributor model is 40698. My vacuum advance unit is 54412170 which has the specs as follows:
5 inch-pounds to activate the unit
11 inch-pounds that will affect the unit
7 degrees of advance which the unit provides.
However, Lucas says I should have model 54411480, which takes only 4 inch-pounds to activate the unit,
(the other numbers are the same for both models)
So my questions are: Does that one inch-pound really make that much of a difference?
and
The unit on my car is at least 31 years old. Does the diaphragm get stiff with old age (like I do!)
and in doing so change the numbers?
If I have to replace it I want to stay with the model I have because the vacuum lines are different
from mine on the "correct" one.
What do you experts say??
FRank :thankyousign:
CJD
Vacuum advance is a mileage thing. The mechanical advance is for power. So, the worst you would see for an advance that comes in later is a very slight difference in mileage. Yes, the diaphragms do get old, stiff and often crack.
Geo Hahn
And I think that difference in mileage would mostly be when cruising at highway speeds with a light foot on the throttle. Under those conditions vacuum is strong and the engine can handle additional advance (which equates to better mileage).
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
S TR2/3/3A Vacuum Advance Union Size Triumph 1
WHT Vacuum Advance Pipe Austin Healey 7
JPSmit Today's question - vacuum advance Spridgets 2
B Vacuum Advance Pipe Austin Healey 2
D TR2/3/3A Vacuum advance tube Triumph 6
C Distributer with no vacuum advance Spridgets 15
Griz Testing Vacuum Advance Austin Healey 5
BJ8Healeys '72 Midget Vacuum Advance Line Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
T MGB Vacuum advance and Electronic ignition conversion MG 5
jfarris TR2/3/3A Vacuum Advance Thread Size Triumph 9
Merlin63Tr4 TR4/4A Gasoline in vacuum advance unit. Triumph 10
jfarris TR2/3/3A SU H6 Vacuum Advance Fitting Thread Size Triumph 2
W BE vacuum advance line and fittings Spridgets 2
W Vacuum advance nipple Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
T TR2/3/3A Is it possible to drill vacuum advance port in SU H6 carb? Triumph 14
AUSMHLY Vacuum advance knob Austin Healey 21
DanLewis Vacuum advance question Spridgets 5
apbos H1 SU vacuum advance frustration. Spridgets 9
DMShuman TR5/TR250 TR-250 Vacuum advance module.... Triumph 5
C TR4/4A TR4A with TR3 distributor and Vacuum Advance Triumph 4
Tinkerman TR2/3/3A 1960 TR 3A vacuum advance line installation Triumph 7
DanLewis Overheating problem solved, or ... did you disconnect your vacuum advance? Spridgets 4
S TR2/3/3A vacuum advance tr3 Triumph 2
S banjo type fuel lines--vacuum advance Triumph 0
D '78 Midget Vacuum Advance Unit Spridgets 7
TulsaFred Bugeye Vacuum Advance Spridgets 5
M a discussion on Installing new vacuum advance unit Triumph 20
DrEntropy Vacuum advance or vacuum leak?! MG 2
SkinnedKnuckles Ported vs Manifold Vacuum Advance Triumph 5
G Anyone have a vacuum advance for a 45DM4? MG 4
Tinkerman TR2/3/3A TR3A Vacuum Advance Suction Tube Tool Needed Triumph 8
Tinkerman I Having A bad vacuum advance line day Triumph 5
Tinkerman TR2/3/3A TR3A Vacuum Advance Line Triumph 2
Tinkerman TR2/3/3A TR3A Vacuum Advance Hook Up Triumph 13
A Mk 1 Frogeye Vacuum Advance Spridgets 6
A Mk1 'Frogeye' Sprite Vacuum advance connections Austin Healey 2
jvandyke vacuum advance question Spridgets 5
Stinger TR4/4A TR4A Vacuum Advance Question Triumph 16
G New Spark Advance Vacuum Triumph 1
L Vacuum Advance question Spridgets 9
C vacuum advance hose Triumph 12
hondo402000 vacuum advance for triple webers Triumph 2
spit71 Spitfire My Spitfire doesn't have a vacuum advance Triumph 14
Tinkerman Vacuum Advance Rebuild? Triumph 2
zimmy vacuum advance Spridgets 17
