TR2/3/3A Lower control arm question
Tr3aguy
I am painting and inspecting the parts of the suspension. I have found on the lower a arm that the brass bushing is worn through to the metal casting. This is on the end that connects to the trunnions. It does not look like the metal is elongated but how do you install a new bushing and then do you need to punch a hole through so the zerk grease fitting will work??
JP
charleyf
The bushing comes with the hole in it. So you just need to press the new one into place--accurately! Protect your metal casting by getting those bushings replaced.
I use a bench vise to press them into place take it slow and easy.
Charley
CJD
The bushing should probably be replaced as a part of the rebuild. The new bushings will have the grease hole, it just needs to be lined up. The bushings come undersize, so they need to be reemed to 5/8" after being pressed in. You can either buy a reemer for around $50 on eBay, or have pretty much any machine shop do it for you for about the same.
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
KVH General TR Pressing in the Lower Control Arm Bushing Triumph 6
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
Tabcon TR4/4A TR4 Lower Control Arm Bushings Triumph 6
MattP Lower control arm bushings MG 4
1 lower control arm bolts? Austin Healey 6
G Lower control arm bushings Austin Healey 8
RCarr BN1 Lower Control Arms Austin Healey 0
KVH General TR Lower Control Arms Triumph 1
BoyRacer BN1 lower control arms Austin Healey 1
TR4 TR4/4A TR4 Lower Control Arms Triumph 2
Racer-X- Metalastik Lower wishbone bushings and upper fulcrum pin bushings Other British Cars 6
S TR2/3/3A lower small brass bushing Triumph 13
S TR2/3/3A steel bushings for the lower Arms Triumph 10
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
R TR6 Lower A-arm trunnion bushings Triumph 18
edkap2002 TR6 lower radiator hose fitting Triumph 2
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B TR2/3/3A lower wishbone installation Triumph 5
L TR2/3/3A Bent lower wishbone arms Triumph 6
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
KVH TR4/4A Should I Cut the Lower Windshield Gasket Triumph 2
C TR6 Lower A-arms Triumph 8
wangdango BJ8 lower radiator hose! Austin Healey 2
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
Rut TR4/4A Lower fulcrum brackets Triumph 3
aero3113 100 lower windshield seal Austin Healey 4
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
K TR2/3/3A The "air vent"on the lower part of the front apron below the grille.... Triumph 5
Jeepster Lower wishbone bush replacement. Austin Healey 33
H Post-War Other Herald rear suspension lower block installation Triumph 3
Scotsman TR4/4A Lower steering flex joint upgrade to TR6 Universal joint Triumph 2
Martinld123 Want to lower car about an inch Austin Healey 4
Rut TR4/4A Lower crash pad Triumph 9
B TR2/3/3A Removing front lower wishbone confusion Triumph 3
M TR4/4A Left lower dash crash pad. Triumph 5
Geo Hahn TR2/3/3A lower generator bolt Triumph 7
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
M TR4/4A Lower crash pads for dash....help. Triumph 4
Keith_M Lower wishbone recondition? Spridgets 5
PAUL161 T-Series Windshield lower rubber MG 5
J TR2/3/3A Lower windshield rubber seal Triumph 3
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
madhouse RF Fender and Lower Cowel Body Parts needed Austin Healey 10
