TR2/3/3A Cooling system normal?
HighAltitudeTR3
My 59 TR3 will blow coolant out of the overflow valve every time I refil it. I don't think I'm over filling it, but it's also hard to tell if I was able to drain the entire system. im also concerned there are air bubbles in the lines... any advice on how to fill, or refill, check level, and/or make sure that I do not have air in the lines?
I also do have the heater...
Thanks!!
Sarastro
You're probably overfilling it. There has to be some room for expansion. Also, be sure the radiator cap is right--they come with various relief pressures. Not sure what the TR3 one should be set for, but it will be listed in the shop manual. Shop manual gives 4 psi for the TR4; I assume the TR3 is the same.
Your altitude may also be a factor. At 7000 ft, atmospheric pressure is about 2 psi lower than sea level, and I think Aspen is around 8000, yes? You might need a little higher pressure cap (maybe 6 or 7 psi?) to compensate, but be careful of too much pressure if you visit the flatlands.
If you open both the block and radiator taps, open the heater valve, and remove the radiator cap, you should be able to drain the system just fine. Flush it with water and a radiator-flush substance from your local parts store, following the instructions on the bottle. Then close the taps, keep the heater valve open, refill with coolant, run the car a bit, and recheck the levels. You shouldn't have problems with air bubbles. None of this is the proverbial rocket science.
TuffTR250
I put a radiator overflow bottle on my 1961 TR3 and every time I drive it I get some fluid in the bottle, although a very small amount. Note that the TR3 radiator will not pull the liquid out for the bottle back into the radiator.
HighAltitudeTR3
HighAltitudeTR3
Thanks for the tips. I had a feeling I was over filling it. Although I don't see any fluid in the reservoir. When I go for a drive I get steam from the overflow tube for a few mins after I shut off the engine. Doesn't seem bad, just doesn't seem like I am getting fluid everywhere in the system.
I'll try what you mentioned and see what that produces. I am running a 7lb cap, which I believe is just fine.
I might try and add a small over flow container just to avoid some of the onlookers concerns. :smile:
martx-5
Are you sure that you have the right cap?? The original cap fits a 1" depth radiator, whereas most caps available today fit a 3/4" depth radiator. A 3/4" depth cap will not seat properly on a radiator that requires the deeper cap.
HighAltitudeTR3
HighAltitudeTR3
Just measured. Definitely have 3/4 (or less:/)
Since I am getting a new one should I get 4lb or 7lb?
charleyf
As the system is set up for 4 lb., I would continue using that. I lived in Durango for many years and drove a TR3 throughout Colorado with the lower pressure cap with no problems.
Charley
Geo Hahn
You definitely need the correct cap - you may find you will need to get it from one of the usual vendors as that long reach is somewhat uncommon in the world of radiator caps.
A 4 lbs cap should be best - does the job w/o additional strain on the radiator & heater core. In the summer I live at 7000' but I also drive in desert heat - if the rest of the system is working well then the stock cap is fine.
HighAltitudeTR3
HighAltitudeTR3
I am debating getting the one from Victoria British. Seems odd it's only $3. Anyone order one with luck from VB?
charleyf
I suspect that you are going to pay a lot more than $3 when shipping is added on. Compare the total cost from the other sources. For myself I do not get parts from VB.
The old saying is-You get what you pay for. In this case you are hoping to get more than you pay for.
Charley
Don Elliott
You should fill the rad so you can see 1/4" to 3/8" depth of coolant as you look down the fill hole. More than this and the excess will just blow down the overflow hose.
When you fill the system, leave the cap off till the engine gets warmed up and re-check the level. If you have an air block or a vapour block the level will drop and you will need to top it up. Make sure the heater valve is open too. Then put a 4 pound cap on securely.
Don Elliott, Original Owner 1958 TR3A
T TR2/3/3A Help - Cooling system problem Triumph 7
steveg TR6 Cooling system filling Triumph 7
D Trying to understand my cooling system Austin Healey 29
7 stupid plastic cooling system parts Other Cars 2
mgedit TR2/3/3A Cooling System Flush Triumph 32
NutmegCT Cooling system clean/flush Restoration & Tools 11
steveg Cooling system filter installation - xpost Austin Healey 6
richie TR4/4A TR4a Cooling system temperatures Triumph 10
mgedit TR2/3/3A 56 TR3 Cooling System Triumph 2
T XKE Series 2 Cooling System Jaguar 0
RJS Cooling System Flush Triumph 3
QuickSilver Cooling System MG 11
hondo402000 TR6 flushing your cooling system, TR6 car specific Triumph 14
Moseso TR2/3/3A TR3 Cooling System Mystery Triumph 4
Dadandson Cylinder Head and Cross flow Cooling system Spridgets 12
KVH Air Pockets in Cooling System? Triumph 7
eschneider Favorite cooling system flush chemicals / brands? Restoration & Tools 3
martx-5 TR2/3/3A TR3 Cooling System Capacity Triumph 5
J oil in cooling system Austin Healey 11
T TR2/3/3A TR3 Cooling system Triumph 15
M Cooling system - thermostat Austin Healey 16
JPSmit Cooling System Question -1500 Midget Spridgets 3
S dish-washer soap in cooling system Triumph 11
Baz Heater box / cooling system Spridgets 8
John_Mc Cooling system flush question part 2 Triumph 3
John_Mc Cooling system flush question Triumph 1
S Wedge Oddities of the TR7 cooling system Triumph 1
sparkydave Darn cooling system! Spridgets 11
N Removing Cooling System Bubble Austin Healey 11
G Filling a completely dry cooling system.... Triumph 13
G Refilling the cooling system . Triumph 1
S Cooling System Question... MG 5
J Cooling System Austin Healey 15
J motor oil in cooling system-100/4 Austin Healey 4
Deanrobert Xke series lll cooling issues Jaguar 5
T TR2/3/3A Water pumps/head cooling Triumph 22
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
D BT7 air ducting / cooling Austin Healey 20
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
F Cooling Austin Healey 3
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
R TR2/3/3A Non Triumph cooling question Triumph 8
apbos Parade Cooling Help Spridgets 12
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
D 2.4L internal cooling passages? Jaguar 4
J Another what cooling fan is this question? Austin Healey 47
H Denis Welch cooling fan arrived today Austin Healey 2
