Erich72TR6
Hello all,
after some time, deliberation, and money, I have sourced a fresh cylinder head that hasn't been shaved to a height a little less than 3.37"... and won't have any detonation problems here on out as I'll have reduced the compression ratio due to the previous head working with .060 pistons. While the head is off, I have been poking around checking various elements of the motor, and was able to discover that my camshaft is indeed an early configuration stock piece, which was a fact unknown to me prior. I've observed its behavior through the tappet holes, and when the #1 cylinder is TDC of its exhaust stroke, numbers 11 and 12 are in their 'fully closed' state, as the lobes aren't visible at all.
Have I got the right idea, or should I pull the timing cover and get a degree wheel to make sure everything is absolutely correct?
One more related question; the picture attached is the #1 intake lobe as seen through the tappet hole. Am I looking too carefully or is the edge of the lobe 'chipped' a bit? The cam and motor have less than 500 miles on it, however I could believe the crook that put it together for me could have used a worn bump stick. He did lie and say it was a 'fast road' cam, anyway.
