Wedge TR8 starter solenoid details?
stever_sl
I have a TR8 that's so massively unreliable I don't dare drive it. Virtually every time I do, it dies somewhere, won't restart, and ends up being towed home. I'm trying to trace the path of current flow during starting and normal running, and I'm having some trouble visualizing what's going on at the starter solenoid. 4 terminals, 1 straight to the battery, 1 to the starter, but what about the other 2? I'd like to see an internal schematic showing how the coils work, and I used to have it years ago, but that computer died and the file is unretrievable. I have an ASCII picture but I was hoping someone had something a bit clearer? This is all part of a big effort to uncover what's actually going on in my car, which had an under-hood fire years before I bought it that resulted in a lot of plain white wires being spliced into circuits, not to mention installation of an upgraded distributor and many wiring detail changes around the ballast resistor and coil. I'm having no end of fun trying to reconcile the wiring diagram that I see most often, and the one in the Service Manual - but it all starts with that solenoid, so any help would be great!
- Steve Richardson
St Louis MO
TR3driver
Great Pumpkin - R.I.P
Always helps if you tell us what year, as they aren't always the same. Here's what I see, based on 3 different schematics:
Of the two side terminals on the starter solenoid, one should be power to energize the solenoid, which is hot only when the ignition switch is turned to 'Start'. The drawings show it as either white/orange or white/red; powered by the starter relay, which in turn gets power from the switch.
The other is an output, a white/yellow wire that runs off to the ballast resistor assembly. It's used to compensate for the battery voltage dropping during cranking, by effectively shorting out part of the ballast resistance in series with the ignition coil.
Internally, the solenoid has two windings, both of which get power from the first connection I mentioned above. One winding is grounded to the case, so it has power applied as long as you hold the key into the 'Start' position. The other winding is grounded through the starter motor, which means it gets power applied only until the main contacts close. It's function is to provide some extra 'oomph' to help move the solenoid plunger, lever, starter drive and so on into the cranking position. But it draws a lot of current and would quickly overheat, so it only gets energized for a fraction of a second while the mechanism moves into place. Once it has moved, the smaller "holding" coil is enough to hold it there.
This diagram is from the TR6 ROM, but I believe the TR8 solenoid is similar.
untitled_5.jpg~original
PS, the above diagram makes it appear that terminals 6 and 7 are connected internally. But I believe the contact is, in fact, split so that they are only connected when the moving contact (the big vertical bar attached to the solenoid plunger) is touching them. Otherwise, the starter motor would short out the ignition when the solenoid is released.
S
stever_sl
Sorry, it's an 80 carbed convertible with A/C, U.S. specs. So the terminal with the white/red wire does the job of bringing the power from the start relay down to the solenoid, and pulls the solenoid over to connect the battery power directly to the starter (5 and 6 in the diagram) and also puts power to the white/yellow wire that feeds the ballast resistor - that's number 7 in this picture? Then that power gets shuffled to various places by the ballast resistor and ends up at the coil and distributor etc. Now I just have to go color-code some things on the total car wiring diagram. There seem to be two, the one that's in the Service Manual and another one that most people seem to use although it has a caution saying it's preliminary info only, but frankly the latter one is easier to follow. Thanks for the help!
TR3driver
Right. Don't forget though, the white wire to the ballast is also hot. And there is no internal connection between WY and WS, the wires only cross. So power from WY doesn't get shuffled at all, it just goes to the coil (via GW) in place of the power that normally comes from the White wire (though an extra resistance).
In my experience on other cars, you don't actually need the power from WY at all. You can disconnect (and tape it up to avoid shorts) and the engine will still start and run fine. The WY connection is mostly useful in very cold weather, when the battery voltage drops a long way while cranking (or if the battery is nearly dead).
TR8%20BALLAST.jpg~original
S Wedge TR8 Starter wiring help needed Triumph 18
S Wedge tr8 starter swap with a 2000 discovery starter Triumph 7
S Wedge TR8 starter dead spot? Triumph 26
V Wedge tr8 starter installation question Triumph 11
JFS Wedge TR8 Starter Wiring Triumph 4
T Wedge TR8 Gear reduction starter Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
S For Sale 1980 TR8 Group 44 Tribute Triumph Classifieds 0
P Wedge Starting problems TR8 Triumph 3
tr6nitjulius Wedge Rare TR8 Triumph 0
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
Hamish Racing TR8 IMSA GTO around Spa Racing 0
MadMarx Wedge Dijon 2019 - Triumph TR8 IMSA GTO Triumph 0
MadMarx General TR Spa Summer Classic 2019 - TR8 IMSA GTO Triumph 1
MadMarx Brands Hatch - Triumph TR8 IMSA GTO Racing 0
MadMarx General TR Brands Hatch - Triumph TR8 IMSA GTO Triumph 0
MadMarx Wedge The IMSA TR8 is ready to go again Triumph 7
MadMarx Wedge IMSA TR8 video with some roar Triumph 0
MadMarx Triumph TR8 at Spa Racing 0
MadMarx Le Mans - YTCC - Triumph TR8 IMSA Racing 1
B Gold TR8 Waxhaw N.C. Spotted 2
MadMarx Wedge Canadian Group 44 TR8 at Hockenheim Triumph 2
MadMarx Wedge TR8 IMSA at Le Castellet Triumph 1
J Wedge TR8 research before purchase Triumph 16
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
S Wanted TR8 with blown motor or no motor Triumph Classifieds 0
T Wedge Triumph TR8 for Sale - 1,020 miles Triumph 3
S Wedge tr8 front end Triumph 0
S Wedge Tr8 manual Triumph 2
S Wedge Need help with TR8 no spark Triumph 7
MadMarx Wedge IMSA TR8 goes on Salzburgring Triumph 6
Rut Wedge TR8 for sale Triumph 1
MadMarx Spa Summer Classic - IMSA TR8 Racing 0
MadMarx Wedge Spa Summer Classic - IMSA TR8 Triumph 7
B Wedge tr8 oil pressure switch number needed Triumph 3
G Wedge TR8 Classified? Triumph 0
G Wedge New to me TR8 Barn find Triumph 8
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
MadMarx Wedge IMSA TR8 - Spax on the rear axle Triumph 3
W TR8 brake aclipers on a Spridget Spridgets 38
MadMarx IMSA TR8 on the NĂĽrburgring Racing 3
MadMarx Wedge IMSA TR8 is racing Triumph 7
tr7andtvr Wedge TR8 Rotor Specs? Triumph 0
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
tr7andtvr Wedge TR8 calipers? Triumph 3
tr7andtvr Wedge Tr7, Tr8 or SD1 3.08 rear needed.... Triumph 25
Mickey Richaud General TR TR8 Folks Triumph 0
T Wedge TR8 parts car Triumph 3
philman Wedge Tr8 on local craigs list Triumph 11
