TR2/3/3A TR3A Seat Bottom Rebuild
PaulLongBl
TR3A Seat Bottom Rebuild [Pics needed]
Does anyone have any step-by-step pictures on rebuilding the bottom seat portion using the Moss seat kit? Plenty of pictures of the back rebuild and completed shots but none on the reassembly/covering of the spring bottoms. I know it's not an overly complicated setup and that I'm making complicated then need be but I'd like to make sure I get it right before I cut anything. Reverse assembly sounds logical but the seats were redone at one time by using only a foam pad placed over the springs, then covered by the seat covering. Thanks in advance for any pics.
DavidApp
Hello Paul
The information is or was out there because I remember reading through it a while back. Unfortunately I neglected to save it and am not able to find it again.
My seats covers appear to be held to the springs with Hog Rings. I am not at home at the moment so I cant add a photo.
Shall be watching this thread hoping that someone will come up with the info.
David
CJD
I'll document mine within the month. Trying to get an estimate from Jonathon Skinner on my interior delivery. In the mean time, these pics may help...
Note that the burlap is stitched to the spring frame to hold it in place...otherwise it will slip over time. Do not use hog rings here, as they will eventually wear through the cover.
The burlap goes completely around the springs, to protect the cover from the wires, that will wear through if left exposed to the covering. It gets hog-ringed to the underside of the frame. The horse hair goes a few inches over the edge of the springs, and also gets stitched in place. The foam in the picture is NOT original. In place of the foam, cotton batting goes over the horse hair. It will stick fine, so does not have to be stitched.
The cover gets positioned on the top, and folded over the sides.
Ensure the factory edging is centered in the back.
This is a poor job...but you get the idea. The sides get stretched slightly over the bottom edges of the frame, and then hog ringed to the inside. You should have some selvage, but not this much.
Hope this gets you started....like I said, a couple weeks I'll be diving in.
Tinkerman
Nice presentation John. That is the way mine were done, though I had an upholstery guy do mine.
Kits came from TRF.
Good luck, Paul
Tinkerman
P
PaulLongBl
I took the big step and went for it. For some unknown reason I was not able to attach two pictures showing the final result. I used the Moss Seat padding kit and covers. Thanks for all the help offered.
SeatB (5).jpgSeatB (6).jpgSeatB (7).jpgSeatB (8).jpgSeatB (9).jpgSeatB (10).jpgSeatB (11).jpgSeatB (12).jpgSeatB (13).jpgSeatB (14).jpgSeatB (16).jpgSeatB (17).jpgSeatB (18.1).jpg
mrv8q
So that's what's under there... good pics!
DavidApp
Just ordered my seats, carpet and weather equipment from John Skinner. So I am keeping an eye on this thread.
Thanks for the photos. Upholstery will be another skill I will have to master on my TR journey.
David
D TR2/3/3A tr3a occasional seat padding Triumph 10
F Wanted TR3A rear seat peg and clip Triumph Classifieds 2
mrv8q TR2/3/3A TR3A TRF vinyl seat reupholstery kit Triumph 7
Got_All_4 TR2/3/3A Triumph tr3a occasional rear seat Triumph 14
Tinkerman TR2/3/3A TR3A seat back, foam thickness? Triumph 1
Tinkerman TR2/3/3A TR3A Post 60,000 seat question Triumph 2
Tinkerman TR2/3/3A 1960 TR3A post 60,000 series seat pan covering Triumph 3
Tinkerman TR2/3/3A 1960 TR3A seat tack strips Triumph 1
Tinkerman TR2/3/3A TR3A Seat spring set needed, Help Triumph 6
Lukens TR2/3/3A TR3A seat pan. Vinyl covered? Triumph 9
J TR2/3/3A Tr3a Fitting Kruso Seat Covers Triumph 19
zmarco TR2/3/3A Occasional Seat TR3A post TS60001 Triumph 12
T TR2/3/3A TR3a back seat Triumph 9
B TR2/3/3A TR3A Seat Height? Triumph 2
T TR2/3/3A TR3A seat piping Triumph 10
M_Pied_Lourd TR2/3/3A TR3A Seat Track Colour Question Triumph 16
toysrrus TR2/3/3A "NEW TRIUMPH TR3A / B" Seat Covers on ebay. Triumph 5
Got_All_4 TR2/3/3A TR3A seat questions Triumph 8
V TR2/3/3A TR3a seat -- is it original? Triumph 7
ekamm TR2/3/3A Rear seat tr3a Triumph 4
TR4nut TR2/3/3A Occassional seat - pre-60K TR3A? Triumph 13
rlandrum TR2/3/3A TR3A Seat Belt Question Triumph 22
CraigLandrum TR2/3/3A TR3A Rear Seat Questions Triumph 13
CraigLandrum TR2/3/3A DIY TR3A Seat Covers Triumph 13
CraigLandrum TR2/3/3A TR3A Seat cushion height? Triumph 10
NutmegCT TR2/3/3A TR3A seat rails from Moss Triumph 22
trglory TR2/3/3A TR3a spark plugs Triumph 1
P For Sale 61 TR3A Triumph Classifieds 1
D TR2/3/3A 59 TR3A Gearbox lever will not move. Triumph 11
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
mctriumph For Sale Project car 61 Tr3a Triumph Classifieds 0
71TR6 For Sale TR3A Nose Triumph Classifieds 0
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
mctriumph For Sale scrapping two 59 Tr3a's Triumph Classifieds 15
J TR2/3/3A TR3A Finally on the Road! Triumph 6
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B TR2/3/3A TR3A Gearbox fluid capacity question Triumph 7
Hamish Racing TR2/3/3A Harewood hill climb Yorkshire TR3a Triumph 3
Hamish Racing Harewood Hill Climb Yorkshire TR3a Racing 0
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 4
J TR2/3/3A 58 TR3A Coil weak? 9KΩ on the secondary with a 1968 HA12 45208A non-ballasted coil. Triumph 1
Hamish Racing General TR TR3a hillclimb Thumdrrstorm video uk Triumph 4
Hamish Racing General TR TR3a faster that a Lamborghini Huracan STO ?? Triumph 6
W For Sale 1960 TR3A for sale Triumph Classifieds 0
G For Sale 1960 TR3A for sale $11,999 Triumph Classifieds 0
