Results 1 to 7 of 7
Thread: Noisy fuel pump
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Senior Member 4tecdog's Avatar
    Join Date
    Oct 2015
    Location
    Wales uk
    Posts
    112
    Blog Entries
    1
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Noisy fuel pump
    Season started for frogeye done a couple of runs this week to check all ok for a few events this year, noticed on a couple of occasions the facet type fuel pump makes a noisy tapping sound but it does not effect performance at all. Appears to start being noisy after about five mile run. Should I be concerned or is it just a characteristic feature of this type of pump? I have seen a few past posts on these pumps but cannot weigh up if they are reliable or not.
  2. #2
    Yoda Gliderman8's Avatar
    Join Date
    Jun 2008
    Location
    PA
    Posts
    7,363
    Thanks Thanks Given
    3
    2
    Thanked in
    Re: Noisy fuel pump
    I have the Facet in my car and YES it does make a "clicking" noise every so often.
    It's annoying but the clicking does stop in short order. That's the norm for the pump... motor on!
    Elliot
    Central PA
    1976 TR6 White/Biscuit interior SOLD
    1973 TR6 Damson Plum / Biscuit interior, HVDA 5-speed, Good Parts Hubs
    Nostalgia isn't what it used to be.
  3. #3
    Join Date
    Oct 2015
    Location
    Wales uk
    Posts
    112
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: Noisy fuel pump
    Thanks for the reply I won't let it worry me then just turn the radio up - forgot no radio have to sing
  4. #4
    Join Date
    Jun 2008
    Location
    PA
    Posts
    7,363
    Thanks Thanks Given
    3
    2
    Thanked in
    Re: Noisy fuel pump
    When I first installed mine the noise concerned me but I soon learned that it was just the way these pumps are.
    You may want to print the warning sticker and place it in your car for passengers... just saying
    Elliot
    Central PA
  5. #5
    Obi Wan Sarastro's Avatar
    Join Date
    Jul 2006
    Location
    Long Beach, California
    Posts
    2,205
    Thanks Thanks Given
    1
    Thanked in
    Re: Noisy fuel pump
    The Facet pumps seem to be noisiest when they are not full of fuel. Today's gasoline forms vapor bubbles very easily, and I suspect you're just getting one in the pump. It goes away after it works the bubble through the pump.
    I had a Facet in my Bugeye and have one now in my Porsche. I've had te same experience as you, in both cars.
    Steve Maas
    1966 Triumph TR4A, undergoing restoration: http://www.nonlintec.com/tr4a
    1952 MG TD, restoration completed 2014, sold 2016: http://www.nonlintec.com/mgtd
    1960 Austin-Healey "Bugeye" Sprite, sold 2010: http://www.nonlintec.com/sprite
    1967 Porsche 912: http://www.nonlintec.com/porsche
  6. #6
    Jedi Warrior SD Bugeye's Avatar
    Join Date
    Jan 2015
    Location
    South Dakota
    Posts
    532
    Thanks Thanks Given
    Thanked in
    Re: Noisy fuel pump
    Isolate it from the car.
    i used two pieces of short fuel,line with washer on ether end
    run bolts thru the pump mounting holes the washer fuel,line washer car body.
    quites it down to near silent
    Door handles,Bootlid,Glovebox all fads
    59 sprite
  7. #7
    Join Date
    Oct 2015
    Location
    Wales uk
    Posts
    112
    Blog Entries
    1
    Thanks Thanks Given
    Thanked in
    Re: Noisy fuel pump
    May have just found one reason for my fuel pump being extra noisy went for a 30 mile ride today and ran out of fuel quarter of a mile from home! Fuel gauge reading nearly half full I'm sure the petrol fairy has drunk some of my fuel 😀
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
