TR2/3/3A Removing windshield stanchions?
karls59tr
Bronze
I have the bolt type stanchions not the Dzus type. I assume that there are captive nuts on the inside of the body where the stanchions attach? Looks like a real pain to free up these bolts. I've allready started soaking them with PB Blaster. Is it worthwhile to drill access holes in the metal cover that hides the nuts. Any advice on removal most appreciated.:grumpy: Also ...anyone have a spare set of "tenon plates" mine have gone missing.
bobhustead
The nuts are part of the cowl. Don't. The bolts should come out with a large square shank screwdriver that fits the slot tightly and is twisted with an open end wrench on the shank.
trglory
Don't know what your commission number is but I believe that later cars did not have tenon plates.
Let me correct this comment.....later cars did not have stanchion plates (between the stanchion and the body) but did have tenon plates (between the stanchion and the windshield frame). Thanks to Geo Hahn for clearing the fog from what's left of this old brain.
TomMull
sp53
Yes those bolts can be a real challenge. Like all that stuff patients and days of soaking is good. I did not try any heat and that is probably not a good idea unless you have a total re-due. I agree the best bet is an impact screw driver with a tip that fits perfect even if you need to grind a tip to fit. When you hit the hammer, remember the bolts are caged in the cowling and the cowling can dent. I would go around and see if I could get at least one out to get an idea about the rust. On a 1961 I did I got 3 out with the impact driver and had to drill and tap the 4th. Like you thought maybe drill out some holes in the back if that does not bother you. If I did that, I would drill then sand blast the rust off from the back and let that soak as I moved on to other stuff.
K
karls59tr
Bronze
That's a good tip about using an impact screwdriver bit. I couldn't find a regular flat tip screwdriver with a wide enough bit. Besides that the bolt head slots have been messed up by a PO trying to get the bolts out previously. I just might go with drilling holes in the back as I think there is a severe rust issue with the captive nuts.
charleyf
By using a Dremel type tool you can "reform or deepen" the slot for the screwdriver. Use the small circular cutting head to deepen the slot. You would consider the screw a throw away anyway so this is not going to hurt anything worthwhile, as long as you do not cut into the stanchions. I usually keep used cutting discs that are rather small to use in cases like this where a large( 1") disc can not be used up next to the stachions.
Charley
TomMull
To confuse the issue a bit more, there were several styles of stanchions on later cars and some did have stanchion plates in spite of the screw fasteners. Most but not all later cars had no grooves for the plates. There seems to be no specific commission number breaks with the various non-dzus stanchion choices. I put the plates in my post 60k windshield, which had the grooves but not the plates, for a much better fit.
Tom
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
KVH TR4/4A Removing Glass Windshield Triumph 4
C Removing windshield from Austin Healey 3000 BT7 Austin Healey 2
M Removing scratches from windshield Triumph 25
R Removing 66 BJ8 Windshield frame Austin Healey 23
L Removing Master Cylinder Without Paint Damage Austin Healey 27
D Removing the steering wheel hub Spridgets 12
J General MG Thoughts on removing a stubborn 2-ear spinner MG 5
Gatheringtree TR2/3/3A Removing the headlamp bezel rim Triumph 2
R TR6 Removing the charcoal cannister considerations Triumph 7
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
KVH General Tech Removing Piston Wrist Pin Triumph 2
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
doakley Spitfire Removing facia Triumph 2
7 Wedge Removing sunroof frame Triumph 5
D Removing the last rust from pitted steel Restoration & Tools 11
D Removing Old Radio Austin Healey 4
S Removing Overdrive Shaft Lever Pin Austin Healey 7
L TR2/3/3A Any trick to removing TR3 doors? Triumph 12
M TR2/3/3A Removing Wires From Stator Tube Triumph 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
longbridgehealey Removing BN4 Bonnet Austin Healey 9
C Removing the Healey "Flash"? Austin Healey 11
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Jim_Gruber Removing a Spridget Engine Checklist Spridgets 5
S TR2/3/3A removing the temp gauge needle Triumph 5
Sarastro General Tech Any good ideas for removing liners? Triumph 20
R TR2/3/3A Removing WD-40 Triumph 6
F Removing oil and water guage from BT7 dash Austin Healey 17
R TR2/3/3A Removing transmission Triumph 3
Joe Schlosser Removing Control Knobs Spridgets 9
W TR2/3/3A Tell me there is a trick to removing lower control arm pin... Triumph 45
Bona42na Spitfire Removing Transmission/Gearbox from underneath Triumph 3
pkmh Removing Passenger Rear Bearing Nut Austin Healey 26
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Removing the ckoke/heater control knobs Triumph 4
Jim_Gruber Removing the Rear Axle Seal Spridgets 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
KVH TR4/4A Removing Rear Differential Seal--Solid Axle Triumph 1
JimTR4 TR4/4A removing the rheostat Triumph 5
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
M TR2/3/3A Can radiator be fixed without removing it? Triumph 20
KVH TR4/4A Removing the Differential Triumph 7
