MGA Correct wheel paint?
Bob Branson
If I'm going to sandblast the wire wheels, I want to paint them the correct silver. Anybody know who has the correct paint for Dunlop wheels, or something that can pass for it?
PAUL161
Everyone has their own idea, but Ford Argent Silver is as close as your going to get. Various brands sell it. VHT has it in a wheel paint. PJ
Platinum
:iagree: That was always the color we've used. Another close one is a Rustoleum silver (for a quick-n-dirty rattle-can job), but the Argent was closest.
TRMark TR4/4A Refurbished Steering Wheel Correct Paint Triumph 6
C TR6 Correct TR6 Wheel Paint Color Triumph 4
F MGB Correct steering wheel - 1974 MG 2
S Correct Size Steering Wheel Austin Healey 1
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
Tinkerman Still Looking for the correct fly wheel ring bolts Triumph 14
W TR2/3/3A Correct thickness for wire wheel spacers [3A]? Triumph 13
P Correct steering wheel for Series III Sunbeam (Rootes) 3
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
