TR2/3/3A Turn signal cancel?
Daves1957TR-3
My TR3 narrowmouth turn signals do not cancel, either direction. I just thought it was a "feature" but recently found out they are actually supposed to! How difficult to fix? Or is the effort even worth it?
Cheers, Dave
TR3driver
Great Pumpkin - R.I.P
It's a bit complicated, so how easy to fix depends on what's wrong. Does the control head turn with the steering wheel, or stay with the slot on top?
TR3driver
If the head is turning with the wheel, then IMO it is worth fixing that. The wires will be twisting every time you turn the wheel, which will eventually tear them up and lead to things like the horn blowing all the time or (more likely) the turn signals not working.
As far as making the self-cancelling mechanism work, that's more of a personal preference, IMO. It's nice to have things working as they should; but not that big a deal to turn the signals off every time.
Daves1957TR-3
I will check that today. I just assumed (ha! ha!) that it was supposed to work that way. I have been focusing on the more "important" issues, like an engine that runs reliably, or an exhaust system that doesn't gas you to death. I just got the stainless steel exhaust parts in last week, will install whenever the weather finally turns here.
CJD
Be careful...it starts as a habit...then grows to an addiction...next thing you know you're checking Ebay every 30 minutes looking for Triumph parts!?!
Daves1957TR-3
Ha! I am already checking Ebay every 10 minutes for Buick parts! The four most expensive words: "While I'm in there...". Applies to surgeons as well.
Control head doesn't move. I am leaving it be! Thanks for the advice!
Cheers, Dave
Kleykamp
Aside from the springs and small parts inside the control head, getting the wiring harness back through the stator tube, etc. the biggest obstacle I found is the slotted grub screws in the steering wheel that have to be turned out to release the head. Those are likely to be rusted in and it doesn't take a lot of twisting to destroy the slots in them...which opens up a big can-o-worms trying to drill out and retro fit. Been there on two out of three that I did.
DavidApp
All this talk about turning head or not turning head made me go and get mine out of the box to check how it worked.
I remember now. Been a while since I looked at it.
David
CJD
Just in case you ever wonder what they look like inside...
It sounds like in yours the cancel assembly has a broken part.
Daves1957TR-3
Thanks for the pix! Leaving it alone for now. If I'm going to learn new curse words it would be more profitable to do that getting the fuel gauge working!
Cheers, Dave
glemon
I wrestled with a similar mechanism in a Healey for quite a while just to get the turn signals to work reliably, there are fiddly little bits inside, I never did get the self cancel to work consistently. I had the assembly apart too many times to count. I think you are making the right decision, and I usually obsess about everything working as designed.
T TR2/3/3A Replacement Turn Signal Switch Triumph 4
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
K TR2/3/3A Turn signal flasher issue.....electrical is not my strong point. Triumph 13
K TR2/3/3A The horn and turn signal assembly. Triumph 3
KVH General TR Green Turn Signal Dash Indicator Triumph 8
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
6 Turn Signal Flasher Spridgets 8
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
B General MG Turn Signal Issue MG 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
M Europa turn signal problem Lotus 7
R Spitfire Turn signal wiring Spitfire Triumph 5
S TR2/3/3A Rear turn signal lamp and trim installation Triumph 5
C TR6 TR6 TURN SIGNAL PROBLEM Triumph 13
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
R Turn Signal Knob goes off center Austin Healey 9
E MGB Turn signal bulb MG 5
Nelson Turn signal beeper. Spridgets 14
M TR2/3/3A 1960 TR3A turn signal harness Triumph 6
M TR6 Turn signal switch stalk Triumph 1
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
K TR2/3/3A Turn Signal Control Head Alignment Again Triumph 1
J 1997 Vanden Plas X300 ,Help With Turn Signal Blowing Fuses Jaguar 3
T TR2/3/3A Is it possible to buy stronger springs for turn signal lever in control head? Triumph 14
B Turn Signal Indicator Light Always Flashing Austin Healey 10
R TR2/3/3A The Turn Signal Challenge Triumph 2
TR3TR6 TR6 TR6 turn signal puzzle Triumph 11
S Turn signal nightmare ! Spridgets 4
S Turn signal nightmare ! Austin Healey 4
N Turn signal flasher?? Spridgets 8
J BJ8 Turn signal help needed. Austin Healey 6
PAUL161 T-Series Turn Signal Flasher MG 8
glemon General Tech Turn Signal Issue Triumph 12
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
R Turn signal switch [trafficator] Austin Healey 1
R TR2/3/3A Turn signal wiring Triumph 1
S Bizarre turn signal issue Austin Healey 10
bighealeysource Turn signal gremlins on BN2 Austin Healey 2
P TR2/3/3A TR3 turn signal and horn control wiring check Triumph 4
bighealeysource Turn signal issues Austin Healey 6
J LED Brake / Turn Signal Austin Healey 4
77MidgetMkIV High Beam/Turn Signal switch issue? Spridgets 21
M Turn signal problem Austin Healey 3
R MGB Turn signal help 67 MGB MG 2
J Horn/turn signal rotate independently of the steering wheel. FORUM Navigation Questions 1
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
A turn signal knocked off center Austin Healey 14
adcronin For Sale MGB New Turn Signal Switches: 62-67 and 68-70 Also 70-73 MBB Steering column cover MG Classifieds 0
glemon TR5/TR250 Turn Signal Wont Blink Triumph 1
