Engine Spitting Back Through Carbs?
stever
Good day, everyone! Question, why would an engine spit back (backfire?) through the carbs when it is first started up and rpms increased? My engine has started doing this recently. I have topped up the carbs with damper oil (from Moss) and the timing appears correct - but it still does it. It only does it until the engine is fully warmed up, then it is ok. Otherwise runs really great, no misses, lots of power, smooth acceleration, etc. Appreciate your help! STeve
RF Thom
Symptom of lean mixture with choke on. Check choke mechanism to ensure that it is moving freely when the cable is being pulled, also watch the mechanism between the carbs again to ensure that it is attached at both ends.
Regards, Bob
aeronca65t
I'll assume that using the choke minimizes this problem (does it?). Sounds like slight lean conditon.
Check fuel filter.
Look for any vacuum leaks (a good test of possible leaks is to spray WD-40 near suspect areas....the engine will ingest the spray and slow down a bit).
Check float level...could be set "low" and you may have to bend float tab.
Dirt in main jet (quick fix: pull piston up and blow back through hole in bottom of float chamber with *low* air pressure or WD-40 spray straw).
Loose or "dropped" needle.
Is you main jet adjusted down the correct amount of "flats"?
Also, never hurts to check plugs and points (just in case it's a bit of "cold" misfire)...and be sure air filters are clean.
ThomP
My BJ8 had this problem from the day I bought it, what I discovered was the one of the needles was not properly located in the piston. The old style needle has no shoulder on it to indicate proper placement in the piston, this needle doesn't even have the groove that some needles do. What I discovered was that one carb would be RICH at idle, and quite lean at normal operating speeds while the other carb was within limits at both speeds. One might think a different needle was required. What I discovered was that by lowering the sholderless needle, I could get the same operating balance as the other carb.
I purchased a Gunson Gastester to discover this problem. Since reseating the needle and adjusting the CO level to about 2.75% at idle, the car has become a dream to start, I can remove the choke sooner in the warm-up cycle and seldom (very cold days choke off too soon) do I have that nasty backfire.
The car came with numerous other little carburetter features that have also been sorted, like the wrong springs, and idle speed adjustment via use of the Fast Idle adjusting screws. These were very easy to find compared to the mis-aligned meetering needle.
Hope you have luck in finding you gremlin.
L Engine ID British Motor Corp 2
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
kodpkd 1961 BT7 engine oil Austin Healey 31
S TR2/3/3A engine removal Triumph 12
R TR2/3/3A Engine stalling and backfiring Triumph 25
M Engine ID Austin Healey 2
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
KVH TR4/4A Engine Installation Triumph 28
P Spitfire Going up-Engine with my Herald Triumph 6
J Engine Parts Suppliers Austin Healey 6
J TR2/3/3A Engine mount Triumph 5
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech More Engine Rebuild Questions Triumph 15
