BN6 Tonneau Cover
maxwedge5281
i have a 1959 bn6 that i have replaced the dash pad in recently. the pad was bought from moss and comes with no markings for fasteners etc. i would like to place the fasteners for the tonneau cover and have a question. do tonneau covers come with the hardware/snaps already affixed or is it up to the installer to match the tonneau attachments to the car attaching points?
British_Recovery
Bronze
Re: bn6 tonneau cover
The dash top mounting points include a turnbuckle on each corner, and a Tenax stud in the center, just to the right of the mirror. Turnbuckles are held by sheet metal screws that go through the dash pad and into the shroud. The Tenax stud also goes through the dash pad, but has a threaded nut to hold it. With the pad removed, the holes and nut should be visible, unless there's been some changes. On most of the new tonneau covers I have seen, snaps and fasteners are included, but not installed.
RAC68
Posted on wrong thread,
Sorry,
Ray
Duane_Rhynard
Picture of the mirror thread holes and the tenax location:
DerekJ
Most tonneau covers come without the snaps attached. They come in a packet and you have to fix them yourself, which is fun. makes sense though because all cars are slightly different.
maxwedge5281
maxwedge5281
i have the dash pad off of my 59 bn6 and there is not a single hole for the tenax stud fastener near the mirror. would this be up to the dealer or the owner to determine and then drill the hole when installing the tonneau cover? also was the nut for the tenax stud held in place by a factory installed captive nut or loose for the installer to place when adding the tonneau?
prb51 BN6 Owners Handbook Austin Healey 14
prb51 BN6 Wheel/Tire Combo Austin Healey 26
nevets BN6 Soft Top Webbing Austin Healey 2
BN6_2197 BN6 Static Timing Austin Healey 2
BN6_2197 BN6 Pulley Diameter Austin Healey 3
BN6_2197 BN6: How to case spikes of the screws of the door panels Austin Healey 17
nevets BN6 horn button Austin Healey 17
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
T For Sale 1959 Austin Healey 100-6 BN6 2.6L Race Car Austin Healey Classifieds 3
G BN6 Battery location Austin Healey 7
C How to remove entire dash panel on BN6? Austin Healey 4
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
G Rollover Bar BN6 Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
BN6_2197 Seat belts in BN6 Austin Healey 15
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
maxwedge5281 bn6 drum brake front hubs Austin Healey 3
V Wanted BN6 Front Seats Austin Healey Classifieds 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
BN6_2197 Fixing the Hood of my BN6 Austin Healey 5
maxwedge5281 modified bn6 history Austin Healey 1
BN6_2197 Adjustment of hand break BN6 Austin Healey 2
M First steps ... & BN6 Austin Healey 4
nevets BN6 rear brake pipes Austin Healey 15
C Healey BN6 water pump and overheating problems Austin Healey 11
maxwedge5281 bn6 spare tire shelf Austin Healey 1
BN6_2197 Adjustment of the Ignition System of my BN6 Austin Healey 22
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
maxwedge5281 BN6 rear quarter panels installation Austin Healey 4
maxwedge5281 bn6 two seater trunk Austin Healey 16
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
C routing of speedometer cable on BN6? Austin Healey 11
BN6_2197 Sun Shades for BN6 in Germany Austin Healey 3
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
A BN6 Top Installation Austin Healey 1
F VIN Problem / Whats difference between BN6 and BN7, bare car. Austin Healey 21
BN6_2197 BN6 brakes not working properly Austin Healey 9
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
David Townsend BN4 and BN6 Limited Edition Prints Austin Healey 30
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
BN6_2197 Removing the Swivel Pin of BN6 Austin Healey 5
BN6_2197 Removing Break Fluid from Bn6 Austin Healey 13
BN6_2197 Disassembling BN6 Front Brakes Austin Healey 14
maxwedge5281 bn6/7 hardtop Austin Healey 18
maxwedge5281 changeover to negative ground in my bn6 Austin Healey 9
