Windshield Installation problems
chris57
So far so good. Got the old posts off with very careful drilling and re- tapping the old screws. Got the new glass in. Got the posts remounted and now I'm stuck. The main gasket between windshield and body just seems to be too much. I don't think I can compress it that much. To make matters worse, the front lip of the gasket interferes with the windshield wiper posts. I think my issue is with gasket orientation or position relative to the bump on the body. Any thoughts?
TimK
Are you sure you have the correct gasket? My problem was the gasket would not make a complete seal -- water would come in under it. I had to add silicone sealant. Therefore, I'm surprised that your gasket is too big/thick.
Keoke
Widshield to body gaskets have been a fit problem since day one of the aftermarket brand try another supply house like Healey Surgeons.?
C
chris57
Thanks for the lead. I just spent another frustrating hour and am convinced this is the wrong gasket. Thought I would return first to Moss and see if I made a mistake and if not try your lead.
GregW
Platinum
I don't know about the gasket, but I'm pretty sure you're posting in the wrong forum. The guys in the Spridget forum will be more familiar with the gaskets that fit properly or any tricks needed to install it.
simon1966 Windshield Installation on BN1 Austin Healey 10
C windshield installation Spridgets 7
sqbsprite TR6 Windshield Installation - on or off the car? Triumph 11
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
P XKE series 1 FHC windshield installation ?? Jaguar 4
I TR6 Windshield washer jets...placement and installation Triumph 1
B Windshield rubber to body installation Austin Healey 22
Stinger TR4/4A TR4A Windshield Installation Question Triumph 7
L Bugeye windshield glass installation Spridgets 13
R Windshield installation. Help needed Triumph 9
Ohiobugeye Bugeye Windshield Wiper Installation OUCH !!!! Spridgets 3
J blew the windshield installation Austin Healey 4
T Windshield installation???? MG 6
B Windshield installation BN6 +7 , BT7 Austin Healey 12
dklawson Spitfire Spitfire Windshield Installation - Mk4 Triumph 4
R Windshield Installation Austin Healey 7
regularman Any windshield installation tricks, tips? Spridgets 17
jhorton3 Windshield Installation Spridgets 3
77_MG_Midget Windshield installation The "EASY" way. Spridgets 4
77_MG_Midget Windshield installation help Spridgets 11
B Windshield Installation? MG 3
J For Sale Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 1
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
