TR2/3/3A rear shelf differential dome
deuce
Hello TR3 guys..I am working on the rear shelf of my TR3-a. Have any of you fabricated the differential dome? I have been trying to use the old shelf as a pattern and it's driving me crazy. My brother was a metal fabricator. He's talking about pi times this and dividing by that. There must be an easier way. I saw something in the Roger Williams book but there's little detail. A layout would be great. Advise would be great. Thanks in advance
DavidApp
Make a card pattern of the part. That is how I do parts that are not flat. Easier to try different shapes to get that dome piece.
Not as rounded but shows the idea.
David
M_Pied_Lourd
worse comes to worse....I have a dome that I can cut out of a parts car....probably cheaper to make on then what it would cost for me to send it to you though :smile:
If you need me to measure something specific, or photos let me know please. I have it on my workbench at the moment....
cheers
tush
TomMull
John, Nice work to say the least but are we missing a few pictures between the first and second above? Is that a patch in the forward part of the bubble?
The bubble itself is not hard to make on a hollow stump. The motorcycle guys do it on gas tanks. The hard part is getting it smooth (planished) after you get the shape in it.
Tom
deuce
Why didn't I think of that..thank you. I made a piece in under an hour that took me I don't know how long to make the mate. I have quit keeping track of time.
deuce
Thanks very much for the offer, tush. I put one together using Davids' paper pattern method. Came out pretty good. I thought I would cut the hole undersize and bend up the excess for a mounting flange..then the stiffeners I made..then..then. Are those your videos on the net. If so..thanks for that. I have watched a lot of them.
DavidApp
His videos are what gave me the confidence to take the plunge with this project. This Forum has helped keep me on course.
David
M_Pied_Lourd
Yes, they are and thanks for watching. As David says, it's a great community effort here from a great bunch of guys. I've had to ask many questions along the way myself and pretty much learn something new every day!
Good luck with your project. Be sure to keep us updated. We would love to hear more about it!
Cheers
Tush
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
K TR2/3/3A Rear tire pressure when there is an anti roll bar at the front of the car? Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
drooartz Bugeye jack points to remove rear axle Spridgets 18
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
R BJ7 Rear Axle Maintenance Austin Healey 5
J Wanted MGA Coupe rear window glass center section MG Classifieds 0
D MG Midget 1275 rear oil seal. Spridgets 0
A Rear Axle Oil Seal Austin Healey 4
