XK120 coor latch question
healeyblue
XK120 door latch question
Still working on the 1951 XK120 body work. I have a question about the door latches. Are they just a single latch or should they double latch? What i mean is when you close the door should the latch click once and be completely closed or should they have to click twice before they are fully closed? So basically what I need to know is should the striker stop on the latch like in the first photo (where the screw driver is pointing) or should it go all the way and stop like in the second photo?
Brinkerhoff
I've got the same car and don't have my latches fit yet so its a great question. That does look like just a single latch though , do the doors fit like they could latch the forward edge ?
healeyblue
healeyblue
I can get them to latch twice but then they are in too far and not flush on the outside. I also have no seals in place right now, so if they do latch twice I will have some adjusting to do before I finish the body work. The doors fit flush now if I latch then just once but I am used to most cars having a double latch for the doors.
Deleted member 8987
You haven't moved the strikers out a bit to see how it works?
If you manually close the latches with door open, do you feel two detents in the latch? If so, it's double, and just move the strikers out a bit.
healeyblue
healeyblue
The door latches are a simple pull latch that latch over a spring loaded wedge. I need input from a 120 owner as they will know what I mean. These are not like more modern car door latches. These are like a door latch you would find on a 1930's car. I could modify the B pillar to allow the latch receiver to adjust enough to allow a double latch, but I want to know what is correct first.
AngliaGT Jaguar XK120 (?) on I581 Spotted 1
C XK120 Interior... and Interiors in General Jaguar 17
M XK120 fuse problem? Jaguar 5
T XK120 fit 140 rack & pinion Jaguar 3
David Townsend XK120 OTS and DHC Limited Edition Prints Jaguar 0
Basil Jag XK120 Drop Head Spotted 2
H Jag XK120 ro=Zagato formerly owned by Scott Gauthier Jaguar 1
David Townsend XK120 FHC Fine Art Prints Jaguar 4
A Xk120 670501 Jaguar 0
LarryK 1953 Jaguar XK120 coupe Jaguar 5
Basil My old 54 XK120 Jaguar 4
J '52 XK120 FHD Coupe fender question. Jaguar 5
J Pics of '52 XK120 FHC project Jaguar 0
GBRandy Barret Jackson XK120 Jaguar 13
Marvin Gruber Any XK120 folks close to Alabama Jaguar 8
Tim_Creger Electrical upgrades for a '52 XK120 Jaguar 10
P Thinking about getting an XK120 Jaguar 16
F XK120 OTS steering box Jaguar 1
bcliff Who Wants a 53 XK120 FHC? Jaguar 5
G XK120 Brake hose needed Jaguar 2
bmurphy7369 XK120 FHC Project Car.... Anyone Feeling Brave? Jaguar 1
Sherlock early XK120 [with alloy body] on E-Bay Jaguar 1
J 1953 XK120 Vehicle Identification # Jaguar 4
D xk120 grill repair Jaguar 1
D xk120 wire wheels Jaguar 1
Basil XK120 pics from member Charles #677556 Jaguar 2
LAW75 Door Latch Adjustment Austin Healey 22
J Early BJ8 Armrest Latch Austin Healey 2
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
C Door Latch Mechanism Austin Healey 3
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
C Bonnet Latch/Release Adjustment Austin Healey 3
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
K For Sale TR3 hood latch assembly Triumph Classifieds 0
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR2/3/3A TR3 hood latch assembly? Triumph 11
maxwedge5281 latch plate shims? Austin Healey 4
R TR2/3/3A Door latch Triumph 6
P Bugeye Hood Latch Spridgets 27
magman BN-1 trunk latch adjustment Austin Healey 1
Rob Glasgow Door Latch Issue Austin Healey 3
Bob Claffie Top Latch Austin Healey 3
E Series 1 jaguar boot latch problem Jaguar 2
Willie_P TR4/4A Tr4 bonnet latch bracket [highly technical] help! Triumph 6
sim 58 door latch Left side Spridgets 8
Rut Front tilt bonnet latch Spridgets 40
maxwedge5281 bj7 hood latch pull Austin Healey 6
maxwedge5281 need hood latch post and body receiver Austin Healey 5
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
