TR4/4A Where to buy this aluminium extrusion?
malbaby
Currently modifying the door glass weatherseal on an aftermarket f/g surrey top.
Looking for some alloy channel...see attached pics.
M
malbaby
Thanks Tom.....the profile that I require is similar to the channel that is attached to the windshield posts.
mallard
It looks like the channel found on the TR6 convertible top. It holds the seal at the top of the door glass. part# 712400 or 621281 Or the seal on the front rail at the top 713036
Sorry TRF part numbers
M
malbaby
This is the C channel that I require as seen in attached pic.
The channel is attached to the windshield frame post to hold the rubber seal.
TR4nut
If you can use steel as you show on the A post picture, I believe that is still available from the normal suppliers. Part number 750163 for example on the Moss-Europe site is the steel retainer for the backlight. Moss in the US has part number 802-060 in 24" lengths.
B MGA Where to Buy, What to Buy? Axle Nut MG 8
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
T TR2/3/3A Where to buy steel TR3A battery box? Triumph 8
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
T Where to buy bolts that secure door latch Triumph 10
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
T Where to buy Factory Grade Paint? Triumph 6
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
RobSelina where to buy springs Spridgets 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
1 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 4
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
