TR4/4A left brake lamp not lighting TR4A
canyon77
Getting 12 volts to contact; left taillight lights up but left side brake light doesn't; bulb is good (repl with new bulb and verified good bulb)
Administrator
Boss
Not sure what car your have but you need to post these kinds of questions in the appropriate Marque forum (for example, if you have an Triumph, post in the Triumph forum, etc). You posted in the "Forum Navigation Help" section, which is reserved for asking questions about how to navigate around in the forum. I am going to "move" your post to the Triumph forum but leave a "redirect" in the Forum Nav Hel section for a few days.
KVH
My guess is it's right there in your wiring, especially if the other brake light works. Replacing bulbs isn't always a "tell all" for me. I've put in new "bad" bulbs, and I've had bulbs not work properly (like an intermittent blink or fast blink) if a bulb on the same side has a problem. I'd look first real hard at the bulb and then the wiring, and be sure all other bulbs work, and that the other brake light goes on.
Geo Hahn
Could be a poor connection including a poor ground where the base of the bulb contacts the socket. The tail light is the dimmer filament and draws less current so perhaps it is able to illuminate despite a poor ground.
You say 12V at the contact but I usually test that with a test lamp rather than just a voltmeter as looking at just voltage can be misleading.
TR3driver
Great Pumpkin - R.I.P
If you try the brakes with the tail lights on, does the lamp go out entirely? That's a classic symptom of a bad ground, because the brake light filaments form a "sneak" ground path for the tail light filament; but only when the brake lights aren't on.
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
jhorton3 Front Left Brake Line Spridgets 9
B TR6 TR6 red brake light len- left side Triumph 9
B TR6 TR6 Red Brake Lens - Left Side Triumph 0
Scott_Hower MGB MGB - Left turn signal wont flash, brake light dim MG 16
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
M Left shock Spridgets 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
Martinld123 My left rear wheel is locking up Austin Healey 16
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
M Wanted Bj8 left front wing Austin Healey Classifieds 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
Tosh TR6 Engine dies slow left turn. Triumph 26
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
F BN7's left Austin Healey 9
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
C Left to right hand drive Austin Healey 2
Lotus Club SoCal Left Coast Octoberfest Lotus 0
T Wanted TR6 Left Taillight Housing Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
Boink Left-hand Drive E-type at Windsor Jaguar 5
John Turney Left Rear Shock Mount Austin Healey 5
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
Popeye TR4/4A Seats - left/right Triumph 8
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
P TR6 Left direction signal no work Triumph 15
D 69 E-Type sputters when making left hand turn Jaguar 6
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
M TR4/4A Left lower dash crash pad. Triumph 5
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 11
K TR2/3/3A Pullsl to the left when accelerating? Triumph 9
AngliaGT What Goes to the Left of the Tach? Spridgets 3
D Problems with left rear turn signal Austin Healey 11
SD Bugeye Are there any of us with 948 builds left? Spridgets 13
