Results 1 to 7 of 7
Thread: 1275 Tranny Rebuild Parts
  1. #1
    Join Date
    Feb 2015
    Location
    Stamford, CT
    Posts
    9
    Chats
    Gentlemen! It's getting right chipper outside, and that can only mean one thing......time to take it in, take it apart, and get started on that winter project of rebuilding your tranny! What? You don't want to spend all that money because collecting all those parts is expensive? You don't say.....well here's the deal you've been looking for. Seeing as I sold my '72 Sprite race car, and the guy who bought it was somewhat of a richard, I still have in my possession a box-o-parts that can be yours. Collected over some time, here's what you get:
    -some parts are moss, mostly victoria though and some good used. I have included part numbers and stampings where applicable. Everything new unless noted-
    1. Moss gasket set (x1) BGK 106 297-700 + various gaskets (see pic)
    2. .004 shim 2-2595 (x4)
    3. Ball 12-1419 (x6)
    4. Layshaft 2-2704 (x1) U.K.
    5. Needle cage bearing 2-2011 (x2)
    6. Spring 2-7289 (x3)
    7. Synchro ring 2-2904 (x1 new U.K.)(x2 used)
    8. Needle cage bearing 2-2009 (x1)
    9. Bearing 1st motion shaft 2-2010 (x1) U.K.
    10. Bearing 3rd motion shaft 2-2013 (x1) used, good shape U.K.
    11. Rear oil seal 2-2253 (x1) U.K.
    12. Needle rollers 2-2010 (x52)
    13. Clutch fork 2-2856 (x1)
    14. Fork boot 9-1018 (x1) used serviceable
    15. Release bearing cup (x1) used
    16. Reverse gear 2-2817 (x1) used serviceable
    17. 2nd gear 2-2815 (x1) used good shape
    18. Laygear 22G83 (x1) used good shape
    19. Syncro hub assembly 3rd & 4th 22G95 (x1) used good shape NLA
    20. Bag of various rib case bits and some thrust washers
    I'm not even going to tell you how much all this cost me, but you can figure it out. "My loss is your gain". Asking $400
    Pull your old box apart and feel good about yourself next spring. Will ship to contiguous 48. Others inquire first please.
  2. #2
    Join Date
    Feb 2015
    Location
    Stamford, CT
    Posts
    9
    Chats
    Re: 1275 Tranny Rebuild Parts
    black friday bump. asking $350
  3. #3
    Join Date
    Feb 2015
    Location
    Stamford, CT
    Posts
    9
    Chats
    Same story......... different year. Still have this kit. Will accept $350.
  4. #4
    Join Date
    Feb 2015
    Location
    Stamford, CT
    Posts
    9
    Chats
    bump
  5. #5
    This looks like a spridget Trans you are posting in the wrong section
    Joe Schlosser
    SCCA National License, Retired
    60 Bugeye, since 1966
    SCCA FP, sold but not forgotten
  6. #6
    Join Date
    Feb 2015
    Location
    Stamford, CT
    Posts
    9
    Chats
    Thanks Joe.
  7. #7
    Join Date
    Feb 2015
    Location
    Stamford, CT
    Posts
    9
    Chats
    Black Friday bump. $300 takes it!
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
