TR6 Fraud warning
Rut
I'm surprised that after all of the blood letting over on BAT and the previous owners comments that the seller still persists in perpetrating this fraud! This should be grounds for a lawsuit.
Rut
TomMull
I read the first page of comments but not the additional 224. I am overwhelmed and still not sure of the specifics of the fraud, but hopefully the bidder at 18k (or whatever the final bid turns out to be) will find enough evidence in there somewhere to negate the sale.
Maybe the bottom line is that eBay is not the place to buy cars. I've bought a couple of cars on eBay over the years, both grossly over represented, but I made that assumption before bidding and bid accordingly. Only got slightly burned.
Perhaps we should do a bit more trading on this forum's marketplace.
Tom
3798j
Bronze
Incredible..an investigation shows an obvious attempt to deceive (and cover up)...then on top of that, the governing body fails to act. Shame on BAT. They lost my trust.
Chris Iaroci
The nice thing about EBay motors is, you're NOT obligated to purchase the vehicle before seeing it/having it inspected. Unfortunately, the deposit (if the auction requires one) is non-refundable though. This happened to me with a Ford Expedition I was buying. The guy totally misrepresented it. When I got there, I turned it down. The guy gave me bad reviews and reported me to EBay, but in the end all of that was thrown out because their rules state you are not obligated to purchase the vehicle. The guy posted it the very next day, with all the same misrepresentations, and EBay did nothing about it. They don't care really. If you're smart, you'll know the rules and inspect the car before handing over any money. Not sure if BAT has any protections, as I have never bought anything there.
T
tdskip
I got a response from the seller as to why they are lying about the condition of the car, again;
"The current description is an honest representation of the vehicle..."
Um, yeah, sure.
HEALEYJAG Ebay warning: Odometer fraud Jaguar 5
D Wanted TR6 hardtop fraud/scam ALERT Triumph Classifieds 5
doc50 TR2/3/3A Fraud on ebay...shocking, I know... Triumph 14
W New or another ebay fraud trick Triumph 8
RomanH Another Possible Ebay Fraud! Triumph 10
roofman Another ebay fraud Triumph 9
WidespreadPanic Textbook case of an ebay fraud/scam Triumph 18
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
Gliderman8 TR6 Handbrake warning lamp switch build Triumph 14
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Gliderman8 TR6 Handbrake Warning lamp? Triumph 8
Cappy Ignition Warning Light Austin Healey 6
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
KVH Off Topic Warning--I'll Be Back Triumph 9
R Speedo High Beam Warning Light Color Austin Healey 14
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
T Ignition warning light remains on and headlights come on Austin Healey 8
N Charging warning light LED conversion Austin Healey 29
W Ignition Warning Light Austin Healey 6
C TR6 Seat belt warning bypass for new harness. Triumph 6
steveg Steering warning Austin Healey 46
steveg Wiper motor install error - warning Austin Healey 9
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
T 1275 engine oil pressure warning light? oil filter warning light?? Spridgets 4
Jim_Gruber Speedhut Gauges- And IGN Warning Lamp Spridgets 16
K TR2/3/3A Headlght warning bulb? Triumph 1
Gerry M TR6 Brake warning light & oil pressure light stay on Triumph 2
7 brake warning light coming on Other Cars 5
M TR6 Pressure differential warning assembly PDWA valve Triumph 4
certifiedcarnut 948 front brake shoes warning Spridgets 5
Gerry M TR6 Brake Warning Light Stays On Triumph 3
K TR4/4A Green and Red Warning Light Removal from Dash? Triumph 5
J MGB Electrical issue- turn signals dim and cause the brake warning light to flash MG 8
B Dashboard Warning Lights Austin Healey 8
J TR2/3/3A Rack & Pinion warning on TR3s-- Triumph 10
B Warning for car buyers- Austin Healey 1
sim Starter warning Spridgets 7
S Spitfire 1973 Spitfire 1500 Dashboard question about warning light Triumph 3
J MGB Question on the brake warning light for 78 MGB MG 6
Scotsman Inoperative Direction Indicator Warning Light Triumph 5
M Ignition warning light? Spridgets 14
R TR5/TR250 TR250 Alternator Warning Light Triumph 21
J Phoenix Upholstery - Warning Austin Healey 0
Jim_Newman Hazard warning lights Austin Healey 1
58Custom Uh oh, what was that? [dial up warning] Spridgets 7
K Any ideas for a Handbrake Warning Light??? Triumph 11
hondo402000 TR6 71 TR6 Brake warning light and oil pressure light Triumph 6
I Brake warning light stays on - help please Triumph 28
J Phoenix Upholstery - Warning Restoration & Tools 0
