What am I and what Terminal do I go to?
Jim_Gruber
Attached is a picture of a disconnected wire discovered in the Regulator Box. I checked the wire that comes off of the negative battery Post Wire and there is a connection to the regulator box coming off of the main battery Terminal to A. So where does this puppy go? Ideas Gentlemen?
Jim_Gruber
Jim_Gruber
Perhaps to E which shows going to Ground. Tested to Terminal E and E is not currently going to ground therefore I believe it should be to terminal E. Affirmations please.
Jim_Gruber
Jim_Gruber
That Black Wire does go to Ground BTW.
Rut
Jim,
Attached is a picture of mine.
Rut
Dan Ka
Here's a diagram from Rick Astley's book "Classic British Car Electrical Systems".
Dan
59 Sprite "Stashek"
AN5L/10918
Jim_Gruber
Jim_Gruber
That's the way I hooked it up. A few more wires to find homes for. Thanks guys. Bought a battery, I need to replace the helmet type battery cable. I can't figure out how you fasten down unless you drill the battery terminal for a screw to hold it in place.
nomad
That is the way! The helmet original type end's actually work quite well and don't seem to corrode up as easily as the common clamp type we normally use. At least that has been my experience.
Kurt.
Jim_Gruber
Jim_Gruber
Kurt, so what type of screw is used. Brass or Stainkess steel machine screw? Size, length? Washer under the screw?
nomad
On the car I still have them on I've been just wedging them on with no screw. That has worked for many thousands of miles. I think I would use a stainless screw if you don't want to try that.
Kurt.
nomad
Kurt.
Not a machine screw. Lead is soft and a short pilot hole should be all that is needed for a short screw.
Kurt.
Jim_Gruber
Jim_Gruber
Thanks, I'll give it a whirl.
Jim_Gruber
Jim_Gruber
Fixed. Thanks Team!
