MGB 1979 MGB coil w/ altered wiring
wingsandwheels
Hi All, want to confirm my understanding of the late MGB ignition and what coil I should be using. Interestingly I've found two different wiring diagrams for this car.
My new to me '79 has the original electronic ignition (external amplifier) but with the resistor wire and ballast resistor bypassed resulting in the coil getting the full ~14+ volts running. The coil is a 16c6 which is a 6 volt coil. I cannot (yet....haven't started unwrapping the blue tape) find the ~9v feed from the resistor wire from the main harness.
My inclination is to return the car to its original spec, figure the engineers had some good reason for what they did, but it is running so well that I am a bit hesitant to change anything. The engine was 'detoxed' by the PO's mechanic. I'd say DPO, but the work and the wiring changes appear to be carefully if not well done:D
My questions are:
Assuming I don't return it to original spec:
-Should I run a '12v' internally ballasted coil such as a Lucas DLB101 or Bosch Blue. Can't see the original coil taking full voltage, but it has lasted so far...
-do I need to run a resistor to the feed to the ignition amplifier? Seems to be getting full system voltage.
-any other thoughts
Thanks all.
bob67bgt
I do not mess with later MGBs but the earlier ones like my 74 have a resistor wire that runs to the front of the car and then back if I recall correct. I do not think you will find a "normal" resistor for the ignition system on your car. Hope this helps!
Joe Reed
Do you have two white/green wires attached to the coil? If so, one is the resistor wire and the other is the feed direct from the starer solenoid...
wingsandwheels
wingsandwheels
Hi Joe, no, that feed is tied away, there is a white feed to the coil and a white feed from the coil to the amplifier. If one of the w/g wires is the resistor and the other is full 12 during starting, I should be able to test that. Odd, the resistor wire on my tr is a large pink wire. Thanks.
w
The Green Hawk
I am currently researching the same ignition unknowns on my car!! Like so many times before, establishing what came on the car originally is half the battle.
I agree with you that the factory setup is the preferred setup......especially with the distributor and ignition systems
Please take a look at the link, I have shared it before but find it a great resource for HEI and CEI distributors
https://worldphaco.net/uploads/CUSTOMISING_A_RELUCTOR_STYLE_DISTRIBUTOR.pdf
Peace
JPSmit
The only thing I would point out, and I think we are talking about the same thing is, having an internal ballast wire is IMHO a bad idea. Our cars (and their wiring) are 40+ years olds, and having a wire in the harness providing resistance and therefore heat cannot end well. With my Vauxhall I have cut out the ballast wire for safety reasons. While origonality is great, upgrades for safety especially are just common sense.
wingsandwheels
wingsandwheels
That thought did cross my mind...especially given how crispy the ballast wire appears on my low mile TR6.
So, as best as I can determine, my car originally had an Opus system that was replaced with the later Lucas system w/ separate amplifier. My current thinking is to bypass the ballast wire and get the proper, internally ballasted coil (effectively back dating the car's set up...essentially the same as my '72 Rover w/ Pertronix).
At this point is my question is does the power feed to the amplifier need to run through the ballast resistor (the OE aluminum finned one) or can it take straight 12v? It is currently getting (and appears to have been for some time) straight 12v and running well........
thanks again all
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
wingsandwheels For Sale 1979 MGB for sale MG Classifieds 0
N MGB 1979 MGB exhaust replacement. MG 1
A MGB 1979 MGB Flasher Big Headache MG 3
T MGB 1979 MGB with Weber carb MG 7
R MGB Testing temp sending unit 1979 MGB MG 6
C MGB 1979 MGB Zenith Stromberg Carburetor MG 3
1979Roadster MGB 1979 MGB SITTING FOR 17 YEARS MG 12
C MGB 1979 MGB steering wheel socket? MG 1
C MGB 1979 MGB door mirrors MG 4
C MGB 1979 MGB Photos MG 6
PAUL161 MGB MGB 1979 MG 2
P MGB 1979 MGB NEWBIE fuel tank replacement MG 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
humanoid For Sale - Haynes Triumph TR7 (1975-1979) Owners Workshop Manual Triumph Classifieds 0
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
FlyingCat Wanted 1979-80 Spitfire Radiator Mount Bracket and Cradle Triumph Classifieds 0
N For Sale 1979 Triumph Spitfire Triumph Classifieds 2
Morris For Sale Fuel Injected 1979 MG Midget Spridgets Classified 0
Z MGB 1979 Timing problems after removing distributor - Help Please! MG 28
T Spitfire 1979 Triumph Spitfire 1500 Triumph 3
T Spitfire 1979 Triumph Spitfire 1500 rear wheel alignment Triumph 4
B Spitfire 1979 Spitfire Emissions Triumph 4
D 1979 Spitfire Spotted 0
R Spitfire Lbs of compression Spec for 1979 Spitfire. Triumph 3
Andrew Mace Wedge 1979 [Fed.] TR7 fuel tank questions Triumph 6
AngliaGT 1979 B Owner's Manual MG 6
startech47 1979 Midget rear hub bearing nut torque spec. Spridgets 3
M zenith float adjustment 1979 MG 1
ronzet Needed EGR valve for a 1979 MG Midget Spridgets 20
H Valve cover paint 1979 Midget Spridgets 8
startech47 1979 Midget Wheel Bearing Numbers Spridgets 0
P 2 midget problems 1979 help! Spridgets 2
B Have Available for Midget [Its from a 1979]... Spridgets 0
B 1979 Midget Wiring Diagram, Harness, etc. Spridgets 6
B Spitfire Sellng my 1979 Triumph Spitfire 1500 Triumph 1
PATR8 1979 MG for sale MG 1
B 1979 MG Midget Headrest available..just pay shipp. Spridgets 2
1979Roadster 1979 OVERDRIVE TRANNIE MG 3
B Help with 1979 Radiator Spridgets 19
B 1979 MG Midget Headrest Available! Spridgets 3
B My 1979 Midget...before and on its way to rebirth! MG 10
kyreb1862 Wedge 1979 TR7 Roadster Automatic Triumph 0
startech47 Static timing a 1979 Midget Spridgets 4
X 1979 LE console removal MG 9
S 1979 rear shock conversion kit worth it? Spridgets 10
S White disk in drivers seat 1979 Midget? Spridgets 3
C Triumph colors from PPG book 1979 Triumph 2
