Triumph TR4 replacement fuel tanks
blhazzard
Everyone,
I wanted to tell everyone some good and bad news.
I have found the archive of articles and discussion from this forum to be immensely useful in restoring my "gift" 67 TR4A. Thanks to you all !!!
The good news is that I am very close to getting it on the road. The bad news is I have some safety concerns with the fuel tank I bought to replace the OEM fuel tank that came with my project car.
If I remember correctly (I have pictures somewhere) the OEM fuel tank for a TR4A was fabricated from two half's that were tack/roll welded along an approximate 1 inch wide edge seam around the entire tank. This lip widened to include the mounting flanges for attachment to the frame. It appeared to be a very strong and solid design except that it ultimately rusts out and needs replacement.
I purchased a replacement (AL, not Fe) tank (will not mention site as they are not the manufacturer) and had it for about 6 months and finally installed it this past weekend. With all new fuel lines and tank I was almost ready to roll. Put a 0.5gal of gas in tank to flush out lines and tank and low and behold there was a leak in a weld on the NEW tank. I had a nagging suspicion that I should have leaked check the tank but had not.
So just immediately pulled the tank (Arrrggghhhh!!!) drained fuel and did some water leak checks.
Pics of tank and closeup of weld area are attached here.
On inspection of the weld these AL (and all replacement tank AL and FE ?) has a relatively complicated weld scheme. I have the following concerns about these tanks :
1) there is not much shear strength on these tanks (back to front half) as there is no large lip with a roll/tack weld - I just see this bead weld on two flange lips which I think could be susceptible to failure due to over pressure and/or shear with a moderate wack to the side of the tank or car.
2) Does anyone have any experience with wrecks with these newer style tanks ?
While the tank is relatively protected by the body it does not appear to take much to just crack the thin bead weld. The lack of a large surface area with the OEM style flange tack/roll weld just makes these appear more fragile IMHO... Comments on this are welcome... I deal in mechanical/material design and fabrication of aerospace parts and this would not be an acceptable in an design for aircraft.
3) Do manufacturers typically leak check all tanks fabricated.
The tank I have has a two year warranty and so we are working it that way but just looking at the design more closely (now that I am not busy working on the car) I am not sure I want this tank...
Are there alternate manufactures for these replacement tanks that incorporate a more mechanically robust design.
All suggestions, comments are welcome...
B
blhazzard
Just a quick update the reseller I am working with has offered to ship a new tank (identical design) but I have put off them shipping it to me. Looking now for anyone who has a non-metallic molded tank.
B
blhazzard
There seems to be no one who has a plastic molded tank as a replacement tank.
Ordering warranty replacement tank from Moss.
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
S For Sale Triumph TR4 Factory Parts and Service Manuals on CD/ROM - 1961 - 1965 Triumph Classifieds 0
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
N For Sale 1964 Triumph TR4 street racer Triumph Classifieds 0
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
M TR4/4A Triumph TR4/4A Steering Column spline size Triumph 1
G For Sale Original Kastner "D" Camshaft for Triumph TR2 TR3 TR4 & Morgan +4, Like-Nu Orig. $420 Triumph Classifieds 1
T TR4/4A 1963 Triumph TR4 Triumph 11
Rut TR4/4A WTB Original Triumph TR4, 5, 6 and Bentley workshop manual for 1967 TR4a Triumph 10
V TR4/4A Triumph TR4 A clutch assembly and gearbox Triumph 6
Stinger TR4/4A 1967 Triumph TR4-A FOR SALE Triumph 9
Triumph_TR4_Girl TR4/4A Second Hand Copy of Original Triumph TR4 Triumph 1
arizonamike TR4/4A Collector's Originality Guide Triumph TR2 TR3 TR4 Triumph 1
CZ_Dave Triumph TR4 Spotted 0
J TR4/4A Triumph TR4 Body Restorer Chicago Area Triumph 3
Atomic8 TR4/4A 1965 Triumph TR4 For Sale - $17,875 Triumph 4
M TR4/4A SVRA NJMP Triumph TR4 in-car Triumph 3
Tabcon TR4/4A Triumph TR4 T3T4 Turbo Charger Kit Triumph 3
C Triumph TR4 racecar build [w/ detailed photos!] Racing 2
3798j TR4/4A A Golden Triumph TR4 Triumph 10
Cabrioman TR4/4A History of the Triumph TR4 and the Surrey Top Triumph 10
glemon TR4/4A Complete Original Triumph TR4-6 Triumph 10
SCguy TR4/4A Triumph TR4 Oil Pressure Triumph 26
SCguy TR4/4A TRIUMPH TR2 TR4 DOOR RESTRAINT ASSEMBLY Triumph 1
KVH TR4/4A Triumph TR4/4A--The Horn Triumph 2
Tim Tucker TR4/4A Book Review Request: "HOW TO RESTORE TRIUMPH TR4" Triumph 5
J TR4/4A Vintage Triumph Register Build Codes Triumph 4
J For Sale Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 2
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
