MGB "Vents" on a new battery?
Flash_Harry
Went out to start our '74 GT one day, and the alternator light went out as soon as I turned the key to start. Only about a week of not being driven, with the battery cut-off activated. So I put it on charge for several hours, and on trying to start all I got was rapid clicking from the relay that serves as a cut-off. When the battery was pulled out, it was wearing a sticker "January 2008", almost a year before I bought the car.
Decided to replace it with a Westco battery, which fits in the plastic battery bin with almost too much room. Now starts with authority, even on cold days.
The battery has what look like two vent tubes on the top. Nothing is mentioned in the instructions about this. Anyone have experience with this?
Harry
Sarastro
Flash_Harry
Flash_Harry
Steve,
Yep, that's them! I wasn't sure whether to put some tubing on them and lead them out of the bin. Maybe I'll just let them alone, as you suggest.
Thanks,
Harry
drooartz
I put a Westco Miata battery in my old MGB. I didn't do anything special with those vents.
Sarastro
I don't know why the battery manufacturers do things that way. Back in the Dark Ages, when I was young, batteries had a single cap for each cell, with a pinhole to let out any gasses that evolved from the cell. Then, they went to two caps that covered three cells each. Now, it's one cap for all six cells. There has to be some way to let them breathe; a pinhole or two would be enough, but maybe there's a concern that a small hole on top might get plugged. At least this way you can't drop a cap and have it roll into an inaccessible spot under the workbench.
PAUL161
Cost to manufacture one long cap is probably a lot less than 6 small ones. Things like that are usually a cost issue. PJ
Merlin63Tr4
Or, like in both my Volvo and BMW, the battery is in the trunk and there is a concern for an accumulation of hydrogen gas in that enclosed space.
So a vent hose is attached to the nipple on the battery to vent the gasses overboard.
M.
Scott_dup1
Yes, those are for venting out of an enclosed space like a trunk. My 1998 Z3 has a battery like that. Also vents acid out if it's overfilled or overflows for some reason.
Joe Reed
Assuming your battery is in the original location, it's vented plenty well :smile: If you've added a battery bin you might want to add the vent tube IF your bin is well sealed up. The holes where the cable run would probably be plenty of venting unless you've sealed those. The other option instead of adding a tube would be to just put a hole or two in the bin to provide that ventilation.
I ended up trimming the very top off my bin. It was thick enough on that top lip to make it difficult to fasten the battery cover. That trimming also provided plenty of ventilation.
Flash_Harry
Flash_Harry
Joe,
Thanks, I do have the bins, and there should be enough air dragged through the holes for the cables. I'm thinking I will leave well-enough alone and forget about adding tubing.
Patrick67BJ8 Hardtop Vents Austin Healey 10
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
HealeyPassion Works Rally Side Vents Austin Healey 24
Darwin Spitfire scuttle vents Triumph 0
M E-type series 1 plastic dash vents Jaguar 1
TulsaFred Proper attachment of Demister tubes and vents Spridgets 3
S General Tech fuel line vents in general Triumph 4
maxwedge5281 rally vents....again!! Austin Healey 6
maxwedge5281 aluminum fender vents installation Austin Healey 14
S Aluminum wing vents for BT7 3000 Austin Healey 1
B Does a 100 Six with no heater have demister vents? Austin Healey 5
Jim_Gruber And these Vents on the valve cover connect to? / Nice Heater hose Valve Spridgets 7
Keith_M demister tubes and vents Spridgets 2
2billydavies TR2/3/3A gas pouring out of the carb vents Triumph 5
maxwedge5281 advice on rally vents Austin Healey 32
maxwedge5281 side vents Austin Healey 16
E TR4/4A TR4 Wooden Dash Facia vents Triumph 13
B AH 100 heater vents Austin Healey 0
B Side vents Austin Healey 4
J New SU Fuel Pump - Gas leaking out of carb vents Austin Healey 24
S big healey fender vents Austin Healey 11
K TR4/4A Fender vents on a TR4? Triumph 17
davidb Big Healey fender vents Austin Healey 23
AUSMHLY Works rally side vents...more than meets the eye Austin Healey 18
v8mgbal Side vents Spridgets 4
R 2500M Vents TVR 3
mountainman TR2/3/3A Tr3 Defroster Vents Triumph 8
HealeyPassion Works side vents project paper Austin Healey 13
DNK TR6 TR6 Vents Triumph 0
NutmegCT H6 carb - float vents Triumph 4
M electrical smoke from cowl vents Triumph 8
hondo402000 TR6 TR6 Eyeball vents Triumph 5
R Side vents Austin Healey 7
Lin Oil Cooler Vents Austin Healey 12
R fender vents Austin Healey 3
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
