TR4/4A Cam Timing with Head Still On HELP!
jeep937
I've been building motors for about 10 years. Mostly chevy stuff with a few model A Fords in there. I'm a bit gun shy in this situation because the 1965 TR4 ran stellar. I only pulled the motor to fix the oil leak and replace the clutch. I left the head on and pistons in. Had to pull the crank because of a broken dog bolt in the snout. It's all going back together now only I can't see to understand the marks and set up for putting the timing gears and chain all back in sync. It sees to say put the motor at top dead center (cotter key down) and the dot on the can gear at 11 o'clock. Well there's two dots. One on the gear and one on the front of the cam. They are in the same area but not real real close to each other. Maybe one at 11 and the other at 10:30.
My question is when I put the crank at TDC and the cam at around 11 o'clock, it seems that there would be a few teeth where it would all fit but could still be off by a couple. These motors have a large dwell cycle so the piston is at TDC for a good amount of time and where exactly does the **** cam need to be? Just before opening of the intake valve? I should have just drawn a sharpie line when I took the gears off. I really don't want to take the head off and degree the cam. Is that the only way?
Darrell_Walker
You should be able to degree the cam with the head in place. Use one of those spark plug hole piston stops to get the precise TDC for the pistons, use a lifter and pushrod to find the lift on the cam.
CJD
Use a straight edge laid over the centers of the crank and cam. There is only one position the cam dot will line up with the crank dot AND the straight edge. If there are multiple dots on the crank sprocket, then set top dead center on the crank and one dot will stand out as correct.
sp53
What John said, I am curious how are you going to seal the rear main after pulling the crank? do you have the engine out and flipped over?
titanic
There is a procedure in the WSM for checking/setting the valve timing that can be used for fitting unmarked sprockets with the head on.
1. Set valve clearance on #7&8 valves to .040", using rule of 9-set #7 valve with #2 fully open and set #8 with #1 fully open.
2. Turn the cam until the clearances on #7&8 valves are equal. One valve will be closing, the other opening.
3. Turn the crank until pistons #1&4 are at TDC. Install the chain&sprocket, taking care not to move the cam. You may have to try different holes in the sprocket or turning it front to back. It is better to have the valve timing slightly advanced 2-3 deg.as chain/sprocket wear will retard it.
Berry
bobhustead
I just replaced the crank sprocket, cam sprocket and chain on mine. On your already marked parts, the crank sprocket has a chisel mark and the cam sprocket has a chisel mark on its perimeter, These two marks and the crtank and cam centers are the alignmen t reference points. They probable wont line up as four points on a line, but the straightest alignment is the one you are looking for. Not possible to get it wrong using the closest possible line approach in that a one tooth error will be a glaring number of degrees and obviously out. The punch mark on the cam needs to be visible thru the open hole in the cam sprocket so as not to get the cam 180 out.
glemon
If you don't trust the timing marks, or they just seem wrong there are many methods for degreeing on the cam on the web. Some made more sense to me or seemed easier to follow than others. I picked out the one that made sense to me and then also had another guy I knew with some experience double check the work before I buttoned it back up.
KVH
See my pic below. I just did all this. Unless someone replaced your sprockets, each will have a line struck in the metal. The one on the crank sprocket is hard to see because it's on one of the teeth. When those are lined up, you're in the correct place. As Berry says, the cam lobes for valves 7 and 8 must be in balance. You can't see the cam with the head on, so you have to watch the valves, and when one starts to close and other starts to open, simultaneously, that's the point of balance and when you're at TDC "on the compression" stroke. Those marks should line up, and if not, maybe the punch holes will approximate what you see in my pic. You'll note that I marked the tiny punch hole in white. Note also the alignment of the other holes. Again, you can barely see the sprocket score marks.
attachment.php
J
jeep937
Thanks guys. I replaced the rear scroll seal. The dog fan bolt was also broken in the crank so I had to take it out anyway. Also everything was leaking. I just went over and threw a bottom end kit at it. Bearings looked good. Found the marks on the timing gears and put it all back.
D Cam Timing question. Spridgets 11
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
B crankshaft/cam timing Austin Healey 10
R HELP - Jensen Healy - Cam Timing Need Photo Other British Cars 19
Dadandson Cam to Crank Timing Spridgets 12
2wrench Timing set on newly installed BP270 cam Triumph 7
T cam timing change Jaguar 4
Brosky Thrusts, cam brgs, crank and cam timing Triumph 5
PAUL161 Question on Cam Timing. MG 5
S crank and cam sprocket timing alignment Triumph 17
RobT Twin Cam Timing Chain Adjustment Lotus 14
Tinkerman TR2/3/3A 60 TR3 Cam Timing Triumph 4
M TR4/4A TR4 Timing, 270 Cam, Pertronics Triumph 3
Morris Spitfire Spitfire 1500 Cam timing Triumph 2
Morris Stock Cam Timing Spridgets 25
M TR2/3/3A Cam timing TR3 Triumph 4
M Timing reground cam Triumph 4
S Timing Cam and crankshaft Austin Healey 6
D 18V cam timing MG 5
J TR 4 Norris Cam 342S Spec Sheet Racing 1
PAUL161 T-Series Crane Cam MG 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
M MGA RHD twin cam steering pinion MG 0
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
S TR2/3/3A Replacing the cam shaft Triumph 27
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
Got_All_4 TR5/TR250 Cam and Lifter Problems Triumph 13
B Installing cam bearings 1275, can I do it? Spridgets 1
B Anyone have a Europa Twin Cam for sale? Lotus 6
J TR2/3/3A Confirming Cam Set Up Triumph 5
G Valve adjustment and easiest way set cam position Austin Healey 15
Walter74 Kent AH4 cam shaft Austin Healey 18
J General TR Cam shaft upgrade????? Triumph 3
S TR6 Quiz .... What cam is this? Triumph 0
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
B TR4/4A Front cam bearing Triumph 8
B TR4/4A Performance cam Triumph 24
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A Kast f cam...301466 Triumph 5
L TR2/3/3A Cam follower rotation Triumph 5
Csarneson BN4 Cam Gear Install Austin Healey 3
N Best cam choice??? Spridgets 5
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
R General Tech Cam measurement. Triumph 6
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
W Cam gear position BJ8 Austin Healey 11
