Jim_Gruber
Here is what happens when you have 2 Son in Laws and 4 Grandsons over for Thanksgiving Dinner. Bugsy has gone from waiting patiently to up in the air and on the rotisserie. Now to figure out next steps. Lot’s of repair work was done to the chassis. I did not realize there was a complete passenger floor installed. Lot’s of detail now that I can see underneath and looks like lots of work. I do see that a DS Floor ought to be done but I’ll ask the opinion of BCF to do some more patching or replace the DS Floor Pan.
Notes to anyone using engine stands for a rotisserie. You need bottom braces once you get things up in the air or you will bend things you do not want to bend. Don't know if I did any bending that is not fixable but I think all is well. When we started things looked like this /-----\ from the angle of the engine stands. Again 2 wheels on the engine stands not the center leg in place. Adding a ratchet strap hooked with the strap hook through the bottom of the engine stand and tightening the ratchet strap changed angles to |-----|. I added bracing using electrical conduit on each side. Rotisserie rotates easily and I can go totally upside down if desired. I left chain hoist running to the ceiling in place with a little bit of tension on it to relieve some pressure on the rear mounts. With chain in place the whole assembly feels very stable.
Anyway I'll ask for opinion, leave the DS Floorpan as is or take the opportunity to replace. Next step will be to roll outside and pressure wash and degrease the chassis. Now to formulate a plan.
