TR2/3/3A Oil Pump Grief
Tropical TR
Due to aggravating circumstances early in the rebuild my original pump was lost. I have heard the horror stories concerning the "County" or reproduction TR3/4 pumps and I guess there is only the one production source which all of the vendors use. One would think that one of the big outfits would have had a decent one produced by now. Of course if one asks a vendor they say that the pumps work OK. Has anyone had good experience in recent years with these repro pumps?
Concerning originals, my first attempt at obtaining a decent item resulted in this:
attachment.php
I haven't checked clearances yet. Does that look like excessive wear?
martx-5
You might want to consider sending that pump to British Frame & Engine. He will "clearance" the pump and will supply rotors (at an extra cost) if necessary. He get's about $70 for the job and of course extra if it needs the rotor and vane. All told it would still probably be less then the cost of a new pump from Moss. Looks like you'll have to send him an email (address on his site), as he no longer has a phone number listed. I sent my original pump to Ken and had it re-done as when I was doing my engine was during the period of the bad pumps, which I believe was a problem with the pin securing the rotor to the shaft.
https://www.britishframeandengine.com/parts1.html
CJD
I can't tell what I'm looking at in the right hand photo. Is that a chunk missing or discoloration? On the left pic, is there a distinct ridge on the right side of the rotor pads?
If the answer to either of my questions is yes...then there is excess wear. If no to both...I can walk you through clearancing the pump.
sp53
I would say that pump is toast. It looks like 2 views of the same pump, but one without the chunks missing? Try contacting Marv on the forum. He has a lot of used parts. Many of the old pumps are re-useable because they had an easy life being dipped in oil. It looks like the pump you acquired there came from an engine that had chunks of metal in it. Some of the people on evil bay also have extra parts when they show something, so you could contact the seller and ask. Good luck
TR4nut
If you are investing in a pump, consider Steve Yott's redesign - racers love it, bulletproof.
Brinkerhoff
A visual exam isn't enough , it needs to be checked with feeler gauges per the shop manual. I've used them many times over with zero problems.
TR3driver
Great Pumpkin - R.I.P
I agree, but I think those photos tell the story. Time for either another original pump, or new rotors. Either way, be sure to check clearances before trying to run it. Many housings have been shortened slightly, to compensate for wear in the rotors (as described in the workshop manual).
+1 on Steve Yott's unit, but they aren't cheap. Cheap enough I suppose, if you're protecting a $10,000 motor, but likely overkill for the street.
T
Tropical TR
Thanks to all for your input. It is all very helpful. More based on what was not said, I am guessing that most of you are not big fans of the reproduction pump currently available...as long as the old ones last. Steve Yott's version is very interesting.
Regards,
KVH General Tech Oil Pump Woodruff Key Triumph 10
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
S For Sale Oil Pump Rotor Assembly for Sale Triumph Classifieds 0
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
A T-Series MGTD oil pump bypass valve MG 0
MikeAH100M Oil Pump for BN2 Austin Healey 4
A T-Series Mgtd oil pump alterations MG 2
nichola TR6 Oil pump drive barely engages Triumph 2
S TR6 After I put in my new oil pump.... Triumph 3
S T-Series oil pump MG 0
svtmikey GT6 Oil Pump replacement Triumph 5
D TR2/3/3A Oil pump question Triumph 31
J TR2/3/3A Oil Pump Wear Triumph 5
H For Sale Healey oil pump drive Austin Healey Classifieds 0
B TR2/3/3A Oil pump rebuild Triumph 4
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Michael Oritt 100 oil pump Austin Healey 5
J Bj8 Oil Pump Austin Healey 2
J 3000 bj8 Oil Pump Austin Healey 38
Jim_Gruber Priming oil pump Spridgets 9
JPSmit Question One - oil pump Spridgets 2
F Video showing oil pump and Kingpin bushing repacement on BJ8 Austin Healey 3
JPSmit New Oil Pump startup Spridgets 8
Rut 1275 oil pump, camshaft adapter Spridgets 2
KVH TR4/4A Using Drill to Spin Oil Pump Shaft Triumph 10
gbtr6 TR6 Prime oil pump in rebuilt engine... Triumph 10
D Not another oil pump question. Austin Healey 7
tinman58 TR5/TR250 OIL PUMP Priming Triumph 3
B Overdrive Oil Pump Installation Question Austin Healey 10
J Denis Welch Aluminum Sump and H/C Oil Pump clearance Austin Healey 18
dcoplan I've got a twisted camshaft-to-oil pump pin. How to fix?? Spridgets 1
BOBBYR oil pump choice Austin Healey 5
RJS TR4/4A Oil leak at/on fuel pump Triumph 7
D Wedge Funny oil pump Triumph 9
johnrip Wedge TR7 Oil Pump Leak Triumph 2
JPSmit Oil Pump Question Spridgets 13
B TR2/3/3A oil pump drive shaft removal challenge on TR3 Triumph 14
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
M Healey 100-4 Oil Pump Condition Check Austin Healey 3
BillW103 Oil Pump Spridgets 24
TulsaFred Oil pump priming access Spridgets 8
richberman Anyone rebuild oil pump gears Austin Healey 1
johnrip Wedge tr7 oil pump leak Triumph 2
B Oil Pump for 100-4 Austin Healey 2
chrpark MOWOG oil pump cover- attachment to back plate? Spridgets 6
richberman Which oil pump? Austin Healey 1
DNK Oil Pump spin up Question Triumph 18
P T-Series Looking for TD Oil Pump Top/Cap MG 0
johnrip Wedge TR7 oil pump Triumph 2
bill_powell Oil Pump Failure? Spridgets 14
