Got_All_4
Went to the store last week and decided to take the 250 and upon start up I heard a strange noise coming from the valve train. Sure enough it was a broken valve spring. #7. Amazing and after a 250 mile trip to the Pittsburgh Vintage Grand Prix with out a hitch. Drove it a couple of times after that.
One of my customers who was a Triumph mechanic in the day told me this story when he was racing his Mini and on the way to the race the truck broke a valve spring. He watched his friend shove a use a clothes line rope into the cylinder bore and bring the pistons up to hold the valves closed and tight to the top. Changed it on the side of the road. I wasn't about to take the head off and do it the conventional way. I just don't have the time and why go through all that if there is a shorter way. I've also been meaning to make a air pressure fitting out of a used sparkingplug in case this ever happens but there is a risk with doing it that way too. Another customer told me that he used too much air pressure and walked away and the air pushed the piston down and the valve fell into the cylinder.
Anyway a 15 hour project came down to a half hour. Now that I know how to do this I could do one in 15 minutes. The valve spring compressor I used is one I made back in 1970 when I used to work on lawn mowers. Worked better the a tool my 2nd customer gave me and couldn't even figure out how to use it. After I was done I took a extension magnet and went into the push rod holes to get any potential chips out of there. There were a few too.
