advice on rally vents
maxwedge5281
i like the idea of the rally vents to help remove heated air from the engine compartment. my car is a bj7 with a sbc 383 roller motor with long tube headers. the headers are wrapped from the engine to the collector. fortunately i took extra precaution with insulation and this car is much cooler in the footbox area than any stock healey i have ever owned. i was also considering hood louvers but i think that i have decided against. that. i bought a set of fender vents with about 1.5 flange and am trying to decide to mount with the flange behind the fender or with the flange on the outside of the fender. i could cut the opening. paint the vent, and glue or bolt in location. i suppose if i was careful enough with the opening i could go back later and weld in place behind the fender and finish the edges for a cleaner look. right now i am leaning toward cutting the flange down to maybe a half inch and mount from the outside. does anyone have a picture of this method that you could post.. yes, i have reviewed the back side mounting with finished edge...so i am really looking for the outside mounting.. any comments will be appreciated. and, is the a general consensus of the placement using the cove line and front fender opening? thanks
TFR1
I installed vents on friends car a few years ago.
Marked openings on fender About 5/8" smaller than vent. Then cut this smaller opening out. I made two wooden forms about a 1/16" larger than the vent. One form was located inside of fender, other form on outside of fender and clamped securely together.
I then gently turned a 1/2" flange to the inside using the wood forms as my guide.
a little hammer and dolly work will leave a very crisp flange turned to the inside of the fender.
Insert vent from outside. Drill through newly made fender flange into new vent for 1/8" pop rivets and secure as needed. I used a total of 6 rivets.
Only a few hours work. Looked great.
hard part was getting brave enough to cut holes in perfectly good fenders.
Good luck.
maxwedge5281
maxwedge5281
i like the look of the vents especially on a hotrod healey.... the body and lines are outstanding and cutting into good fenders is a bit harrowing! but, i want to move more air through the engine compartment. i suppose it is just my want to for the car. TFR1, did you turn the fender metal down all the way around or just in the straight line areas of the vent opening! did you remove the fenders? do you have a picture? seems i saw this some where on the forum! maybe i can find it via the search function.
RAC68
Hi Reid,
As I have come to understand and experience, the Big Healey engine compartment is not effectively designed and builds up high pressure to partially stagnate effective air flow. When this happens when at idle (stopped), air build and finds easier escape around the steering box only to be pulled back through the radiator with the use of more aggressive fans (i.e. Texas Cooler, etc.). When driving casually, air will enter between the cross member and, with the contribution of an aggressive fan, will also build a blocking high pressure and also cause a less then free flowing escape path.
With the introduction of bonnet louvers as on the 100/4s or the addition of wing vents, air flows freely back and out resulting in a cooler running system. Although I have not installed vents or louvers, I have created a number of panels to help direct and guide air paths to escape more effectively without being obvious. A more effective approach would be to have a effective separation by the radiator bulkhead to eliminate air from passing into the engine compartment without going through the radiator. However, on a completed car, this approach would be very difficult to implement and, for many, vents are far more stylish and easier to implement.
Ray (64BJ8P1)
maxwedge5281
maxwedge5281
yes, thank you ray...that was what i was trying to say......but it is still a daunting task to cut perfectly good wings for the vents! still working on building up the courage. thanks for the explanation.
Editor_Reid
Platinum
Thanks Ray. I get the theory of wing vents (allowing hot air to escape and therefore achieving better engine compartment air flow), but I'm not convinced that we have good evidence that they are needed or even very helpful on mostly standard cars. They were installed on competition cars that were expected to be driven far more aggressively than anyone drives a street Healey. If you're considering installing wing vents to reduce engine running temps on your babied street Healey, you have other issues.
If someone just likes the look, fine, but to my eye they look out of place as a competition car feature on a street car, and particularly out of place on a Healey with roll-up windows which would be a pretty civilized touring car and far removed from the character, purpose and use of the factory rally cars.
It also hurts resale value as it is a multi-thousand dollar proposition to return to standard wings, and collectors who pay the best prices do not appreciate previous owners' personalization - modifications just make them seem more like used cars.
Just my take of course.
Reid Trummel
Special Operations
Sports Car Market magazine (scroll down)
Bob_Spidell
Agree with Reid (FWIW). As an owner that puts 5-6K miles/year on a BJ8--much of it in the Southwest including deserts and Death Valley--I've never felt the need for vents. Make sure your block is clean and install an uprated radiator and you'll be fine.
John Turney
Bob, Reid,
I hope you realize that we're discussing a Healey with a 383 V-8 in it. Originality is already out the window and air flow through the engine compartment is somewhat blocked by a larger engine. I agree that on an original car, wing vents and other mods that are expensive to reverse ar probably not a good idea, but for those of us who are not at that starting point, a little individuality is IMHO ok.
HealeyRick
Don't forget Maxwedge is driving a V8 car in South Carolina so I'm sure he's trying to do everything he can to keep it from overheating. I'd still like to see some empirical evidence regarding the efficacy of rally vents. Should be pretty easy if someone with the vents bought a cheap infrared laser thermometer from Harbor Freight and did a couple of tests of engine temperature both at idle and after a high speed run with the vents taped up and untaped.
Bob_Spidell
Bob, Reid,
Didn't realize that. Disregard; car's already hacked so do what you will with it (of course, you can do that with an original car, too, but it's a value losing proposition.
RAC68
Reid/All,
As the woman who kissed the cow said, each to his own taste. Whether you like louvers on the hood of a 100/4 or vents on the wings of a 100/6 or 3000, these elements do allow air to flow more efficiently through the engine compartment, and as a result, allows the escape of heated air from the compartment. Our Healeys are loveable but not perfect and most of our heat issues are the result of a porous radiator bulkhead and other similar engine compartment flow approaches of the period that were expeditiously addressed by cutting holes in the body panels. It would be difficult and impractical to reengineer the compartment's design to take advantage of modern techniques but louvers and vents were already found by the original designers to satisfy some of the more critical heat issues and is period correct .
Reid, your car may have been manufactured with louvers but I wonder if, at the time, there were those questioning the style and sensibility of cutting into the bonnet. Although I have added many modifications to address heat build-up in the engine compartment, all of which are as inconspicuous as I could design, it would have been easier if I had just take Donald's approach and vented through bodywork.
RAC68 (64BJ8P1)
Editor_Reid
Platinum
Reid, your car may have been provided with louvers when purchased but I wonder if, at the time, there were those questioning the style and sensibility of cutting into the bonnet. Although I have added many modifications to address heat build-up in the engine compartment, all of which are as inconspicuous as I could design, it would have been easier if I had resorted to Donald's approach and vented through bodywork.
RAC68 (64BJ8P1)
Actually the car in my signature photo was/is a standard car. I ended up owning a louvered bonnet from one of the 640 100M models (long story), and so when it was restored I chose to use it. It's an authentic item and was used on cars sold to the public. (Unlike wing vents that were only seen on factory competition cars, and were never used on cars sold to the public, even as an option).
I am fortunate to own two more standard BN2s and each of them is completely stock-standard in the cooling department (and pretty much in every other way, too). They even have their original fans. Both run cool (I should probably install warmer thermostats - they run that cool). Makes me wonder if a lot of our problems are the result of trying to improve things. Of course in the case of a Healey with a big American lump for an engine, all bets are off.
maxwedge5281
maxwedge5281
i will have to say that the v8 conversion runs much cooler than my bn6 and a whole lot faster. some of us just drive to a different tune...and speaking of a big lump...700 pound 130 hp engine seems a bit lumpish to me!
TFR1
I had the fenders on my work bench. Much easier than on the car, but certainly could be done either way.
I turned the metal 90 degrees. You end up with a great edge to attach the vent. I have seen others do the same and fit the vent from the inside. Not sure if there is a right or wring way to do this. I am better at taking pictures now, but do not think I took pics at the time.
TFR1
maxwedge5281
maxwedge5281
thanks for the input from the forum. one of the vents is warped from fabrication or from shipping damage and will have to be returned. i am still having a hard time deciding to cut my fenders. if i do i think that i will reduce the overall size of the flange and leave it on the outside of the fender following the advice to cut the fenders and turn an edge to affix the the vents to the car. flash!!! decided to return the vents to healey surgeons and leave the fenders alone....now i will consider hood louvers! anyone have a picture of louvers on a 3000?
RAC68
The choice is yours as both have been used as styling points and functional components on many of the worlds most popular cars. However, placing louvers into the bonnet may be a little more difficult as the incorporation of hood louvers will imposes some considerations and difficulties. I believe your previous choice of fender vents provides you with the easiest approach to venting the compartment and removing the vents will require a patch and paint but louvers will require a bonnet replacement.
There are alternatives to vents and louvers and a few forum members are looking to see how to effectively address the issue of a porous radiator bulkhead without tearing apart the car. At present, however, no easy fix to the issue of radiator recirculation has been secured and vents and louvers have the benefit of having been proven.
Good luck,
Ray (64BJ8P1)
Top Down Resto
What I did on a customers car many years ago was use 3/8 rod made to fit my final vent outline, tacked it to the back of the vent hole and then hammered the metal to a nice neat radius inward. Vent was metal and with out the flange, I had to move the channel support back a little and simply tacked it to the inside of fender and was done. Very neat and if I remember just the way the factory ralleye cars had it done. This was done to make a replica works car and run in the Tour De France in '99.
I think your on the right track by having a hood louvered , easy to replace to stock, side vents do look cool, almost did it to my 65 BJ8, glad I didnt, as Reid said if the factory had it done in a production car it could have been easily have been a dealer install.
However you can get a spare set of fenders......
let us know the outcome
Carroll Phillips
Top Down Restorations
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
R Remove engine/transmission advice needed Austin Healey 4
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
B TR6 Windscreen removal advice Triumph 10
