MGB The easy way to get the oil pressure relief cap nut back on
max71
I've been dealing with low OP and trying experiments on changing springs, packing, etc. Everyone I talked to who did this job said its hours of work and one of the most miserable jobs with the engine in the car. After having a special tool made and trial and error I got it down to ~ 20 minutes and pretty painless. I once took the car to a mechanic who spent almost 2 hours trying to get it in using a lift.
Here's the recipe:
1. Get some kind of spreader. I bought a tool that was used to remove C clips and had a couple parts welded on. Photos attached.
2. Known tip: Play with the cap nut to find where it starts to thread in and mark that place.
3. Although the tool I made was meant to be used just with the cap nut directly the problem arose when trying to turn the nut due to very limited space. So using a tip from Peter Burgess, I cut down a 1" socket. You cannot get the socket wrench in there until the nut is pretty far down. So I put put a lock tie on the socket with the nub positioned to where I could get to it with the socket positioned where the threads start on the cap nut/block. (see above) and mark the socket to correspond.
4. With everything in place (also a bolt at the bottom of the socket so it can be held by the spreader) you just begin to use the spreader worm screw until it mates up with the threaded hole. Not difficult but may take a couple practice runs to make sure its straight in
5. Use whatever you can to then spin the socket/cap screw using the nub from the lock tie. One full half turn does it.
6. Unscrew the spreader and turn the socket by hand until its pretty close to the block
7. Take you socket wrench and finish the job.
Really easy. If you require more photo's let me know. BTW, make sure to use a copper washer or copper crush washer. The fiber washer that many parts houses sell leaks.
Platinum
This task seems sooo easy from the innocuous look of that cap nut from the outside. It's only when you try compressing that spring for the first time with the engine in situ, you find you've opened a can of worms!
First time we did this was back in the late sixties. Took a couple hours of MacGyverin' different levers, tool "repurposing" and general thrutchin' about accompanied by colorful language before it finally caught the threads.
Congrats, Max! Well done.
davelinkson
Refitting oil pressure relief valve cap
A tip on refitting the cap to 4-cylinder cars more than anything else.
Bearing down against spring pressure whilst trying to get the threads engaged is one of those 'worst jobs' on the MGB. Refit the cap without the spring, slowly unscrew it, and mark the cap and block where the threads just disengage. Now you can refit the spring and position the cap just before the threads will engage and not only will you know where the threads will engage, but also that whilst fighting the spring you will only have to turn the cap a few degrees to do it.
PAUL161
Max, thanks for that bit of info! Any way this job can be made a little easier is very welcome. Good job! :encouragement: PJ
Simmo
Here's the recipe:
Simmo
Hi Max, I am totally frustrated with installing this spring and nut. Your article seems to solve the problem but it still confuses my small brain. Could you please send me some more pics so hopefully I can understand your method. Cant seem to invisig the assembly with the Tool and Socket together. If you are using the socket for the final screw down and it doesnt assemble with the took, OK. Then show me how the tool worked with the nut and spring, that is with compression weight. My email is : secsimmo@bigpond.com
Regards
ian
JPSmit
Ian this is a thread from 2015 and Max has not been seen on the forum since 2016 - so hopefully some others will chime in. Good Luck!
bobh Easy way to remove the original oil filter and can Triumph 13
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Basil Easy way to clean fuel injectors (out of car) Other British Cars 2
T General Tech Once again, check the easy stuff Triumph 2
Basil Easy[er] way to get frozen brake rotors off Restoration & Tools 13
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
H Typical Easy Project takes me 2 hours. Spridgets 5
H Steering Wheel Removal after being attached for 58 years. Nothing is easy. Spridgets 6
maxwedge5281 easy to get side-tracked! Austin Healey 5
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
4tecdog Headlight relays the easy way Austin Healey 13
CZ_Dave MGB Easy off Oven Cleaner!?!?!?!? Yuppppp! MG 9
Joe Reed MGB Another easy fix....upper radiator bracket MG 5
tomshobby General TR making it easy to lube door hinges Triumph 0
J Nothing is ever easy! Austin Healey 12
drooartz MGB-GT Easy come, easy go -- my GT is sold MG 2
T Post-War Other Nothing's easy Triumph 6
andrea PROP ROD BONNET RATTLE easy solved Austin Healey 9
J Poly Lower A-Arm Bushings - One easy question as I am confused Austin Healey 1
RAC68 EASY Sunday Morning Austin Healey 1
M Tie rod end came apart easy - too easy? Spridgets 6
H two easy questions Austin Healey 14
Boggsy64 MGB Rear end washers easy MG 1
T It's not easy being Green Triumph 7
Cottontop Don't we WISH it was this easy Restoration & Tools 5
HealeyRick 1500 Engine Rebuild Made Easy Spridgets 5
58Custom Is it easy to convert a '69 US dash to a pre-67? Spridgets 21
Brosky Easy add on fuse block Triumph 7
HealeyRick Restoring a Healey is Easy Austin Healey 7
glemon Quick Easy Removeable Cupholder Triumph 4
Trevor Jessie Easy overview of rocker geometry Spridgets 11
Morris If only it were this easy...[ a bit OT ] Spridgets 5
JPSmit Light hit, easy fix Other Cars 4
58Custom Iinstall pre-pillow dash in pillow-dash car? Easy? Spridgets 2
dklawson Solvent Pop - Is There an Easy Fix? Triumph 10
T Why couldn't it be this easy? Triumph 6
H JACK MODIFICATION FOR EASY REAR END LIFTING Triumph 9
A Easy way to remove Cylinder head? Triumph 13
Jim_Gruber Starter goes Click-Oh how easy this car is to fix Spridgets 1
steveg Easy simple product helps eliminate gas gauge flu Austin Healey 0
germanmichel Easy way to move the 3litre engine out of the car? Austin Healey 7
N T-Series Is there an easy way to remove clutch M/C? MG 4
drooartz Bugeye engine removal is easy! Spridgets 8
B MGB 72 mgb speedo drive seized.....easy fix? MG 11
T TR6 Fry a TR6 electrical system in these easy steps Triumph 16
6 Please say it's easy...Dash pad removal Austin Healey 4
Jayrz Oh that was TOO dang easy! Spridgets 8
S Here's an Easy One - Inner Tube Question Triumph 14
T TR4/4A TR4A floor pan removal - easy or hard? Triumph 7
