TR2/3/3A Speedo in KPH
6TTR3A
Does anyone out there have a Triumph sidescreen speedometer that reads in Kilometers?:driving:
I know they must be rare since very few countries were on the metric system in the '60s,
but the parts book lists one so I'm hoping.
Frank
Geo Hahn
I too have seen a few usually on cars that also had a mechanical temp gauge in C°. Unfortunately they were also used on some TR3 derivatives (e.g. Italias) and that won't improve the asking price if you find one.
Simmo
A few years back I searched in vien for a KPH Speedo for my XKE. No luck what-so-ever. Eventually a Instrument repair guy got mine repainted, by hand, from a lady who painted clock faces. It looks better than a factory made one. Maybe this will give you leed in another area to look at people who make clocks or something like that.
Geo Hahn
So if you use that face then the only thing that is off are the odometers (which will still measure miles)? Those, I suppose, require a gear change inside the head.
CJD
I am sure Jesus will show up soon. We had some online discussions about the gears for the odometer. I have no doubt that the speed needle can be calibrated for either KPH or MPH. So, only the odometer would be off...by a good bit. I think he managed to find the correct gears...but I am not sure.
Jesus
Thanks for the introduction, John.
Yes, I am in the process of converting a MPH speedo into a KPH one, reproducing the original look (very little progress since our last contact, John). How to get a new face has been already mentioned (John can print the right figures and symbols on an old face with excellent results).
The gears for the odometer must be changed to go down from 1180 tpm to around 740 or 730 tmp (1180 divided by 1.61 – 1 mile = 1.61 km), depending on the tire size. I salvaged the gears with the required number of teeth from another Smiths speedo, and got both odometers to count kilometers.
Now I need still to calibrate the needle and install the face to finish. For the calibration I am building a fixture with an electrical motor to drive the speedo at variable speed, so that I can do the job on the bench.
Jesus
6TTR3A
6TTR3A
Thanks to all for the replies...I kind of figured it was almost a lost cause (unless I win the lottery!!)
The answer is do the face & live with the odometer & trip meter. I'll go that route.
Thanks again.
FRank
HerronScott
Frank,
Why do you want your speedometer in KPH? Just curious since your location shows San Diego. :smile:
Scott
6TTR3A
6TTR3A
Very late to the party, but my speedo is in KPH
Crankshaft,
I don't suppose you would be interested in a trade ?
I've got a Concours quality Speedo (in MPH) to trade,
plus any amount ($$$) in addition that you feel is fair.
PM me.
FRank
Brook
Dear CJD
I should be very grateful if you would let me know how to get a KPH face for the speedometer of my TR3A.
With many thanks
Brook
B TR4/4A TR4a Speedo.....KPH! Triumph 18
philman 220 kph speedo Triumph 2
R TR6 Speedo Experts: Troubleshoot question… Triumph 10
J TR6 speedo Triumph 0
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 4
mctriumph For Sale Speedo Cables Supra / Tr Triumph Classifieds 0
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
J Wanted Original BJ 7 speedo Austin Healey Classifieds 0
algot1901 1950 Prefect Speedo Cable Other British Cars 8
George Zeck Speedo Cable? Spridgets 3
Dnickels Spitfire Speedo help Triumph 4
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
R Speedo High Beam Warning Light Color Austin Healey 14
P TR6 72 TR6 Speedo cable Triumph 2
4tecdog Speedo drive gear Spridgets 15
N Speedo identification? Other British Cars 4
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
F TR6 speedo gear reduction Triumph 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
T TR2/3/3A Question on overdrive pinion & bearing assembly for speedo drive Triumph 11
Jeepster Oily speedo Austin Healey 8
Bob_Spidell Disassemble Speedo Adapter Austin Healey 2
S TR4/4A What is the routing for the speedo cable Triumph 2
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
MY66AH Speedo rebuild Spridgets 5
B TR2/3/3A Gearbox speedo drive seal Triumph 1
longbridgehealey Speedo cable from 59 Bugeye Spridgets 1
MY66AH Speedo problems Spridgets 15
doc50 TR2/3/3A Speedo WAY off... Triumph 10
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
Patrick67BJ8 Speedo calibration Austin Healey 22
paul9999 Speedo...just gets quicker and quicker! Other British Cars 2
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
mgedit TR2/3/3A Bouncy Speedo ... Lubrication Triumph 4
trotti Speedo ignition light Austin Healey 12
B Speedo needle Austin Healey 3
Rut MGB OD install, speedo drive gear MG 0
doc50 TR2/3/3A Speedo reads way too low Triumph 13
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
Gerry M TR6 Speedo Angle Drive Triumph 2
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
E TR4/4A Speedo v Tach cable Triumph 2
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
Gerry M TR6 Speedo Angle Drive Triumph 9
F Speedo problem BT7 - cable rotates but speedo does not Austin Healey 25
Gerry M TR6 Speedo stopped working Triumph 6
M TR2/3/3A TR3 Speedo cable Triumph 4
