Welder Choices?
bammons
I would like to buy a welder. Probably would not be interested in a TIG or learning a Stick welder. Would like not to spend too much money. I am 70 and have a MGA and a Triumph TR250 left to restore. I will need to weld sills, battery trays, and floorboards etc. Little other use other than mower decks and such. I would like to buy a flux core so I don't have to fool with gas cylinders. So here are my questions: Are flux welders good enough to do good work now? Who makes a decent one (preferably USA made)? Will I regret getting a flux core for my limited use and wish I had bought a MIG? Thanks Bruce
GarMan
Hobart MVP210 MIG welder. Not expensive, does a good job and is dual voltage. I use a small gas 75/25 mix. Bought it a few years back for metal sculptures but works great on my 77B. My 2 cents:smile:
B
bammons
So Flux core welding is harder? Not as good a weld? I only have limited use for one was hoping to hear Flux core would do the job. Bruce
Popeye
Bronze
I have heard - but please do not believe everything you read on the internet, and I have only experience with gas - that flux core results in a messier weld, ie more time to clean afterwards.
Basis this I bought a gas MIG from Hobart. Gas bottles require decent initial investment - regulator and bottle - but are cheap to refill.
GarMan
Not really harder, but messier. I did it for a few months before getting the gas. You can purchase an inexpensive small 20lb cylinder or just go flux core. They both will do the job.
bobhustead
Although MIG machines will generally I think run flux core ) mine does), the two processes are not the same thing. Sheet metal needs MIG. Lincoln, Hobart, Miller are good, but made in factories in many countries. I would buy quality.
B
bammons
I am looking at a Mig/Flux 140 that Eastwood has. It is capable of 3/16" and priced decently. They have a tech line as well. It is Chinese made but all reviews (whatever they are worth) are good. I probably need to just bite the bullet and put a little more $$$ into it and get a gas bottle. This machine would allow both so I am covered if flux doesn't satisfy me. Seem from above most are more satisfied with MIG so that is why I asked and will not ignore all of your advice. Bruce
R Welder Austin Healey 27
S TR2/3/3A spot welder at HF Triumph 6
I Off Topic Good auto body welder in Wa state? Triumph 7
Trevor Jessie I let the smoke out of the welder Spridgets 10
T Which Welder to Buy? Triumph 21
68_sprite welder? Spridgets 0
JPSmit Hypothetical welder question Restoration & Tools 24
bighealeysource Harbor Freight mig welder Restoration & Tools 1
PAUL161 HF 240 Spot Welder Restoration & Tools 1
t_bush Northern Tool fluxcore welder mini review Restoration & Tools 12
SilentUnicorn Help me chose a Welder Restoration & Tools 10
jackq spot welder Restoration & Tools 8
Jim_Gruber MIG Welder Wire Size Spridgets 20
J Welder purchase Triumph 3
BritCarFan 110 or 220 Volt MIG welder Restoration & Tools 18
S welder Triumph 3
mrstinson Welder Recommendation - TIG or MIG Restoration & Tools 15
KLUTZ Would I need to buy a welder for this? Triumph 14
M Welder Advice Triumph 12
G Welder advice... Triumph 0
G Welder advice... Restoration & Tools 6
Patton Horrible Freight MIG Welder??? Restoration & Tools 6
Popeye General Tech O/D right angle drive choices Triumph 10
2wrench TR6 Help with points and condenser on '74 TR6 -- or better, choices to get rid of 'em. Triumph 25
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
H Tire choices for Bugeyes Spridgets 14
R TR6 Cam choices? Triumph 23
TomMull Hylomar and sealant choices Restoration & Tools 15
T Wndshield choices Austin Healey 8
SASSAMON TR2/3/3A Distributor Choices Triumph 2
2 TR2/3/3A TR2 Coil choices Triumph 5
B Camshaft choices Austin Healey 11
simon1966 Current day grease choices? Austin Healey 3
J TR2/3/3A Headlight choices, Carillo shells Triumph 1
J Confusing Seat choices for 1969 Mini British Motor Corp 8
J TR2/3/3A Suspension choices, rubber vs poly Triumph 8
tahoe healey Coolant choices Austin Healey 5
4 Oil choices for an Austin Healey BN1 Austin Healey 4
4 Oil choices for an austin healey BN1 FORUM Navigation Questions 2
R Insurance-carrier choices Austin Healey 10
R_Lyle TR6 TR6 wheel choices Triumph 10
K Carb Choices Triumph 3
J headlight choices ?? for BJ8 Austin Healey 5
S Interior/Exterior color choices........help? Jaguar 12
Ed_K Valve cover gasket choices ? Austin Healey 5
dklawson Spitfire Spitfire - Oil Filter Choices Triumph 8
drooartz Brake pad choices Spridgets 6
glemon TR5/TR250 Bearing/Rings Choices TR250 Triumph 6
N Fan Choices [& More] Austin Healey 21
RobT Trailing Arm Bushes - Help - Too Many Choices Triumph 12
